The following code outputs, to the Serial connection, the difference in time between when the ISR and loop function is called. I would expect is delta to be low but it can be up to a millisecond. Can someone explain why this is happening? BTW, this is test code. I wrote it to track down and isolate a problem I'm having with a big program. Right now, I'm just concerned with how it runs on the Uno board. Also, my tests have been on the 1.0.1 version of the IDE.
pinMode(9, OUTPUT); // for testing (toggling)
#if defined(USBCON)
TCCR1A = 0;
TCCR1A = _BV(COM1A0) | _BV(COM1B0) | _BV(COM1C0); // for testing (toggling)
TCCR1B = _BV(WGM12) // CTC mode (TOP = OCR1A)
| _BV(CS10); // clk/1
#else
TCCR1B =
0b01 << 3 | // WGM13:2 = 1, CTC (Top = OCR1A) (see TCCR1A)
0b001; // CS12:0 = 1, clkI/O/1 (No prescaling)
TCCR1A =
0b01 << 6 | // COM1A1:0 = 1, Toggle OC1A/OC1B on Compare Match. for testing (toggling)
0b00; // WGM11:0 = 0, CTC (Top = OCR1A) (see TCCR1B)
#endif
OCR1A = 16000; // 1mS
TIMSK1 = _BV(OCIE1A); // enable interrupt
unsigned long max_delta = 0;
unsigned long last_isr = 0;
#define BEGIN_CRITICAL_SECTION \
{ unsigned char oldSREG = SREG; cli(); {
#define END_CRITICAL_SECTION \
} SREG = oldSREG; }
unsigned long delta;
delta = micros() - last_isr;
max_delta = max(max_delta, delta);
if (!(millis() % 1000)) {
Serial.println(max_delta);
max_delta = 0;
// called once per mS
ISR(TIMER1_COMPA_vect) {
last_isr = micros();
