I am trying to write a function that fades through the colors on the rgb spectrum, while actively waiting for a button press to exit the function. For some reason the pixels get the initial color but doesn't fade. However it still gets a button press.
Here is the function. I can verify that Wheel() and checkButton() work, but if you want I could post the rest of my code.
//fade through colors
int changeColors(uint8_t c) { //the changeColors function is called when there is a long button press
int b=0; //initialize the button state value to zero
while (b == 0 || b == 4){ //this loop runs as long as the button state is 0 or 4
strip.fill(Wheel(c)); //fill the strip with 1 color. Wheel() takes an 8 bit value and returns a 32 bit rgb color
strip.show(); //push the command to the strip
for(uint8_t i=0; i<50; i++) { //loop 50 times = 50ms
delay(1); //delay 1ms at a time = 50ms
b=checkButton(); //check for button state and load it in b
if (b != 0 && b != 4) break;//breaks out of loop if the button state is not 0 and not 4
c++; //increment the color value each loop
} //if we break out of the for loop it also shouldnt repeat the while loop
EEPROM.write(COLOR_ADDR, c); //save the color value for next time
return b; //return the button state to activate the next mode
I can also verify that it's not a SRAM issue by changing the code to light up only 1 pixel.
I'm wondering if anyone can spot anything simple/stupid that I am overlooking.
Thanks for any help I can get.
I am more fan of using boolean functions (bool changeColors), but int should work well too.
Anyway, the program should work fine with J-M-L 's approach.
I dont know either why 0 and 4 ethereal numbers to check, but it would be great if you could post the rest of the code.
I need a 50 ms delay between every time I increment the color value.
Here is the rest of the code. I didn't comment it all, but I hope you can get what I'm trying to do.
/* The lights are connected to the
* Trinket's pin 1 through a resistor. A pushbutton is connected from
* pin 0 to ground. You can use the pushbutton to cycle through the modes:
* Uses the Trinket's EEPROM to store the mode, so it is retained
* when the power is off.
#ifdef __AVR__
#include <avr/power.h>
#endif
#include <EEPROM.h>
#define SWITCH 0
#define PIN 1
#define COLOR_ADDR 1
#define MODE_ADDR 0
#define N_MODES 4
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// NEO_RGBW Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(5, PIN, NEO_RGB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit...if you must, connect GND first.
boolean copMode;
// This is for Trinket 5V 16MHz
#if defined (__AVR_ATtiny85__)
if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
// End of trinket special code
strip.begin();
strip.show(); // Initialize all pixels to 'off'
// initialize the SWITCH pin as an input.
pinMode(SWITCH, INPUT);
// ...with a pullup
digitalWrite(SWITCH, HIGH);
copMode = digitalRead(SWITCH);
// Button timing variables
int debounce = 20; //| ms debounce period to prevent flickering when pressing or releasing the button
int DCgap = 250; //| max ms between clicks for a double click event
int holdTime = 1000; //| ms hold period: how long to wait for press+hold event
// Button variables
boolean buttonVal = HIGH; //| value read from button
boolean buttonLast = HIGH; //| buffered value of the button's previous state
boolean DCwaiting = false; //| whether we're waiting for a double click (down)
boolean DConUp = false; //| whether to register a double click on next release, or whether to wait and click
boolean singleOK = true; //| whether it's OK to do a single click
long downTime = -1; //| time the button was pressed down
long upTime = -1; //| time the button was released
boolean ignoreUp = false; //| whether to ignore the button release because the click+hold was triggered
boolean waitForUp = false; //| when held, whether to wait for the up event
boolean holdEventPast = false; //| whether or not the hold event happened already
int checkButton() {
int event = 0;
buttonVal = digitalRead(SWITCH);
// Button pressed down
if (buttonVal == LOW && buttonLast == HIGH && (millis() - upTime) > debounce)
downTime = millis();
ignoreUp = false;
waitForUp = false;
singleOK = true;
if ((millis()-upTime) < DCgap && DConUp == false && DCwaiting == true) DConUp = true;
else DConUp = false;
DCwaiting = false;
// Button released
else if (buttonVal == HIGH && buttonLast == LOW && (millis() - downTime) > debounce)
if (not ignoreUp)
upTime = millis();
if (DConUp == false) DCwaiting = true;
event = 2;
DConUp = false;
DCwaiting = false;
singleOK = false;
// Test for normal click event: DCgap expired
if ( buttonVal == HIGH && (millis()-upTime) >= DCgap && DCwaiting == true && DConUp == false && singleOK == true && event != 2)
event = 1;
DCwaiting = false;
// Test for hold
if (buttonVal == LOW && (millis() - downTime) >= holdTime) {
// Trigger "normal" hold
if (not holdEventPast)
event = 4;
waitForUp = true;
ignoreUp = true;
DConUp = false;
DCwaiting = false;
holdEventPast = true;
buttonLast = buttonVal;
return event;
// Fill the dots with a color
int singleColor(uint8_t c) {
int b=0;
strip.show();
while (b == 0 || b == 1){
b=checkButton();
return b;
//wipe a color across the dots
int wipe(void) {
int c=0;
int b=0;
while (b == 0 || b == 2){
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(c));
strip.show();
for(uint8_t j=0; j<100; j++) {//wait 100 ms but keep checking button
delay(1);
b=checkButton();
if (b != 0 && b!= 2) break;
c = (c+120) % 255;//choose next color☺
return b;
//blink like a police car
int copBlink() {
int b=0;
uint16_t n;
uint32_t c;
while (b == 0 || b == 3) {
if ((i+n) % 4 == 0){
c = strip.Color(0, 255, 0);
else{
c = strip.Color(255, 0, 0);
strip.setPixelColor(i, c);
strip.show();
n+=5;
for(uint8_t j=0; j<150; j++) {//wait 150 ms but keep checking button
delay(1);
b=checkButton();
if (b != 0 && b != 3) break;
strip.clear();
strip.show();
for(uint8_t k=0; k<75; k++) {//wait 75 ms but keep checking button
delay(1);
b=checkButton();
return b;
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
uint8_t mode = EEPROM.read(MODE_ADDR) % N_MODES;
uint8_t color = EEPROM.read(COLOR_ADDR);
if (mode == 0){//for first start
mode=1;
if (mode > N_MODES){//keep from hanging above
mode=1;
if (copMode == false){
mode = 3;
copMode = true;
switch (mode) {
case 1:
mode = singleColor(color);
case 2:
mode = wipe();
case 3:
mode = copBlink();
case 4:
mode = changeColors(color);
EEPROM.write(MODE_ADDR, mode);
I would rewrite the animation functions so that they only do "one step" of whatever animation is on-going and manage them as small independent state machine and handle the button in the loop
(you have a lot of EEPROM.write(), you should probably use update() instead of write() )
using the OneButton library would probably make your button handling easier to Read / implement
What is your Arduino ? why do you possibly include <avr/power.h>?
An EEPROM write takes 3.3 ms to complete. The EEPROM memory has a specified life of 100,000 write/erase cycles, so you may need to be careful about how often you write to it
what update() does is to read the memory first and if this is a new value, then write it.
I’m using an Adafruit trinket
probably some clean up needed but the most important work is probably to make the display functions asynchronous and non blocking
Thanks for the help and tips guys. With the help of the OneButton library I finally got it to work. Some of your other tips helped me get it down to less than half the lines of code.
