Just got a new display https://www.ebay.com/itm/2-8-TFT-LCD-Touch-Screen-Expansion-Shield-w-Touch-Pen-for-Arduino-BE/192019148675
but it just displays white backlight, using Adafruit_TFTLCD / GFX
Thought it was be an easy kit but now it's way over my head!
Testing with MCUFRIEND_kbv diagnose_TFT_support I get:
Diagnose whether this controller is supported
There are FAQs in extras/mcufriend_how_to.txt
tft.readID() finds: ID = 0x4001
This ID is not supported
look up ID in extras/mcufriend_how_to.txt
you may need to edit MCUFRIEND_kbv.cpp
to enable support for this ID
e.g. #define SUPPORT_8347D
New controllers appear on Ebay often
If your ID is not supported
run LCD_ID_readreg.ino from examples/
Copy-Paste the output from the Serial Terminal
to a message in Displays topic on Arduino Forum
or to Issues on GitHub
Read Registers on MCUFRIEND UNO shield
controllers either read as single 16-bit
e.g. the ID is at readReg(0)
or as a sequence of 8-bit values
in special locations (first is dummy)
reg(0x0000) 00 00 ID: ILI9320, ILI9325, ILI9335, ...
reg(0x0004) 04 04 04 04 Manufacturer ID
reg(0x0009) 08 08 08 08 08 Status Register
reg(0x000A) 5B 88 Get Power Mode
reg(0x000C) 0C 0C Get Pixel Format
reg(0x0061) 20 20 RDID1 HX8347-G
reg(0x0062) 20 20 RDID2 HX8347-G
reg(0x0063) 20 20 RDID3 HX8347-G
reg(0x0064) 27 24 RDID1 HX8347-A
reg(0x0065) 24 24 RDID2 HX8347-A
reg(0x0066) 24 24 RDID3 HX8347-A
reg(0x0067) 24 24 RDID Himax HX8347-A
reg(0x0070) 20 20 Panel Himax HX8347-A
reg(0x00A1) 20 20 20 20 20 RD_DDB SSD1963
reg(0x00B0) 20 20 RGB Interface Signal Control
reg(0x00B4) 24 24 Inversion Control
reg(0x00B6) 24 24 24 24 24 Display Control
reg(0x00B7) 24 24 Entry Mode Set
reg(0x00BF) 2C 2C 2C 2C 2C 2C ILI9481, HX8357-B
reg(0x00C0) 00 00 00 00 00 00 00 00 00 Panel Control
reg(0x00C8) 08 08 08 08 08 08 08 08 08 08 08 08 08 GAMMA
reg(0x00CC) 0C 0C Panel Control
reg(0x00D0) 00 00 00 Power Control
reg(0x00D2) 00 00 00 00 00 NVM Read
reg(0x00D3) 00 00 00 00 ILI9341, ILI9488
reg(0x00D4) 04 04 04 04 Novatek ID
reg(0x00DA) 08 08 RDID1
reg(0x00DB) 08 08 RDID2
reg(0x00DC) 0C 0C RDID3
reg(0x00E0) 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 GAMMA-P
reg(0x00E1) 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 GAMMA-N
reg(0x00EF) 2C 2C 2C 2C 2C 2C ILI9327
reg(0x00F2) 20 20 20 20 20 20 20 20 20 20 20 20 Adjust Control 2
reg(0x00F6) 24 24 24 24 Interface Control
