I'm doing a project where I will be making a robot to play a tin whistle.
I'll be using 7 solenoids and possibly a variable flow valve for air. I'll need to program the arduino to play the music. Which model do you think would be best suited?
Not a 74HC595, not enough drive current.
TPIC6C595 (100mA per output), TPIC6B595 (150mA), or TPIC6A505 (350mA) would likely be better choices for solenoids and a flow valve.
Attiny not much memory either (8K). Uno (32K), 1284P board (128K), or Mega (256K) likely a better choice.
CrossRoads:
An important fact is that the 1284P has twice the SRAM of the 2560 (16K vs 8K).
I've actually been growing to like the 1284P more than the 2560. I have not yet ever needed 256K of flash, but having lots of RAM has helped me several times.
For the development, a Mega would be a good choice if you want to stick to a native Arduino (1284 based boards ain't as far as I know). Once your setup and code are complete, you know how many pins you need and how much memory. You might find that it all fits on/in e.g. an Uno and use that for the final implementation.
