Unused I/O pins when LCD shield is used
Grumpy_Mike:
If it was not the last shield in the stack you would not be able to see the LCD!
right, it does not make sense to be able to stack another shield on top, but that does not mean you should not be able to use the unused pins anymore. I believe the lcd shield has through holes to solder a female header so you can use jumper wires to use the pins not used by the lcd shield.
