The board says me....
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I´m working with an old Arduino diecimila with Atmega328 chip an Arduino ide 0017.
thx.
thx.
Unwire everything, check if the port COM is correct, plug usb and reup.
If u got the same error, reinstall arduino board or try it on a different pc.
Hoping isn't the board.
few days ago i was testing my programing skills with arduino, windows xp 32, arduino s3v3 with armega328 and arduino IDE 0017.
i got the avrdude error.......... this happened after making a lot of successfull uploads.........
i searched, googled. looked everywhere, tried everything.
nothing worked..... then i made myself a parallel programer (without the resistors, i was in a hurry) changed my computer, (my new one does not have parallel port), and burned the bootloader to the chip.....
it worked very good, the same day ordered another s3v3 with an extra atmega328 chip........ and again burned the new chip with the bootloader........ cero problems.......
if you want, after making all the testing you see on the forums, if nothing works, do as i did........ also recomended to have a spare burned chip, just in case........
""""" this is an answer i allready posted....""""""
