Unusual syntax - explanations required
I am working on a project using multiple MAX31865 breakout boards (SPI).
I found a code example (see below), which works, but I would like to adapt this example to my project.
It is a little difficult as I do not understand some of the syntax.
I suspect it is probably efficient code, but as a beginner I cannot follow it.
  1. the line...... "float operatMax31865_1(void) {.....
    this looks and works like a function, but why does it include data type 'float''?
    ..and why does it have ..(void).. Not seen this before.
    Functions I have seen before use syntax "void functionName() {
  2. serial.print('/ ');
    this results in display of "12064" Don't know what this figure represents
    It disappears if I comment-out.
    Never seen this syntax before - what does it mean/do??
Just curious...and hope to learn something new
Help appreciated.
#include "SPI.h"
#include <Adafruit_MAX31865.h> // Adafruit's Header file
// Use software SPI: CS, DI, DO, CLK
// Adafruit_MAX31865 max = Adafruit_MAX31865(8, 10, 11, 9);    // ss, mosi, miso, sck
// use hardware SPI, Write your CS pin
Adafruit_MAX31865 max_1 = Adafruit_MAX31865(8);
Adafruit_MAX31865 max_2 = Adafruit_MAX31865(14);
Adafruit_MAX31865 max_3 = Adafruit_MAX31865(31);
Adafruit_MAX31865 max_4 = Adafruit_MAX31865(35);
#define RREF      4300.0 // 4.3Kohm
#define RNOMINAL  1000.0 // PT1000
  float temperature_1 = max_1.temperature(RNOMINAL, RREF);
  return temperature_1;
float operatMax31865_2(void) {
  float temperature_2 = max_2.temperature(RNOMINAL, RREF);
  return temperature_2;
float operatMax31865_3(void) {
  float temperature_3 = max_3.temperature(RNOMINAL, RREF);
  return temperature_3;
float operatMax31865_4(void) {
  float temperature_4 = max_4.temperature(RNOMINAL, RREF);
  return temperature_4;
 max_1.begin(MAX31865_3WIRE);  // set to 2WIRE or 4WIRE as necessary
 max_2.begin(MAX31865_3WIRE);  // set to 2WIRE or 4WIRE as necessary
 max_3.begin(MAX31865_3WIRE);  // set to 2WIRE or 4WIRE as necessary
 max_4.begin(MAX31865_3WIRE);  // set to 2WIRE or 4WIRE as necessary
  Serial.print("PT1000_1: "); Serial.print(operatMax31865_1()); Serial.print('/ ');
  Serial.print("PT1000_2: "); Serial.print(operatMax31865_2()); Serial.print('/ ');
  Serial.print("PT1000_3: "); Serial.print(operatMax31865_3()); Serial.print('/ ');
  Serial.print("PT1000_4: "); Serial.println(operatMax31865_4());
Can someone please explain the following
Look here for information on Arduino function declarations.. Float is the return data type. You have to include an argument list even if it is empty. You can just have empty parenthesis () or you can put (void) to say that there are no arguments.
  1. serial.print('/ ');
That is not right. The single quotes is for single characters, double quotes for more than one character (a string). '/ ' is 2 characters, a forward slash and a space. It should be "/ ". And '/ ' should generate a warning. Do you have compile warnings turned on in preferences?
See this: Is it better to use C void arguments "void foo(void)" or not "void foo()"? - Stack Overflow
Original code
I can only assume the double quotes got lost when formatting the sketch for the web page.
groundFungus:
Turns out multi-byte character constants are a thing, and the value provided is implementation defined.
https://en.cppreference.com/w/cpp/language/character_literal
Notes
Multicharacter literals were inherited by C from the B programming language. Although not specified by the C or C++ standard, most compilers (MSVC is a notable exception) implement multicharacter literals as specified in B: the values of each char in the literal initialize successive bytes of the resulting integer, in big-endian zero-padded right-adjusted order, e.g. the value of '\1' is 0x00000001 and the value of '\1\2\3\4' is 0x01020304.
