Trying to set up a voltage ladder for a single analog input into multiple digital outputs. Everything seems to be working the way I want (with a few minor hiccups that I will look into fixing). The problem I'm having and can't figure out where I'm going wrong is - when I press any of the 4 buttons, it seems like I need to hold it until the voltage drop occurs. Delay is around 0.5-1 second, depending on the button pressed. I would like instantaneous response from all of them. Like a keyboard, or video game controller. It is going into a race car to control signals/power output/other things. The outputs themselves don't matter, but I want the button pressed to be left on until I press the button again, AND I would like a master switch to control power to all the buttons AND the outputs given. i.e. If master switch is on and I press a button for hazards, a separate button for rev limit and a separate button for some sort of cooling system, I would like the master switch to turn off all those outputs as well as supply the buttons.
Any diagram help or programming help is appreciated! I know I'm missing SOMETHING.
I've only tested my finished concept on tinkercad, so if its a delay with THAT software, that would be the easiest fix
```cpp
// Define the analog input pin (for the voltage ladder)
const int analogPin = A0;
// Define the digital output pin
const int outputPin1 = 3;
const int outputPin2 = 4;
const int outputPin3 = 5;
const int outputPin4 = 6;
// Define voltage thresholds for each button (adjust as needed)
const int switchOn = 1000;
const int button1Threshold = 100;
const int button2Threshold = 600;
const int button3Threshold = 760;
const int button4Threshold = 900;
// Variable to store the current state of the output pin
bool outputState = LOW;
// Set the output pin as an output
pinMode(outputPin1, OUTPUT);
pinMode(outputPin2, OUTPUT);
pinMode(outputPin3, OUTPUT);
pinMode(outputPin4, OUTPUT);
// Set the analog input pin as an input
pinMode(analogPin, INPUT_PULLUP);
// Initialize serial communication for debugging (optional)
// Read the analog value from the voltage ladder
int analogValue = analogRead(analogPin);
Serial.print("Analog Value: ");
Serial.println(analogValue);
delay(10);
// Check which button is pressed based on the analog value
if (analogValue > button1Threshold && analogValue < button2Threshold) {
// Button 2 pressed
Serial.println("Button 2 Pressed");
if (outputState == HIGH) {
digitalWrite(outputPin2, LOW);
outputState = LOW;
digitalWrite(outputPin2, HIGH);
outputState = HIGH;
delay(70);
} else if (analogValue > button2Threshold && analogValue < button3Threshold) {
// Button 3 pressed
Serial.println("Button 3 Pressed");
digitalWrite(outputPin3, LOW);
outputState = LOW;
digitalWrite(outputPin3, HIGH);
outputState = HIGH;
delay(70);
} else if (analogValue > button3Threshold && analogValue < switchOn) {
// Button 4 pressed
Serial.println("Button 4 Pressed");
digitalWrite(outputPin4, LOW);
outputState = LOW;
digitalWrite(outputPin4, HIGH);
outputState = HIGH;
delay(70);
} else if (analogValue < button1Threshold && analogValue != 10) {
// Button 1 pressed
Serial.println("Button 1 Pressed");
digitalWrite(outputPin1, LOW);
outputState = LOW;
digitalWrite(outputPin1, HIGH);
outputState = HIGH;
delay(70);
Serial.println(" ");
// Add a small delay to avoid rapid toggling
Also, I can't seem to figure out how to post a photo
Are you really using 10Ω, 15Ω, and 20Ω resistors in the resistor ladder? Those values are way too low, 5V across a 10Ω resistor will produce a current of 500mA.
According to the sketch, there are NO actual buttons unless I am going blind. The wiring diagram, however, does have four buttons. You will also need to learn about bouncing, and you should check the pinned posts on almost any Category to do with a state machine or 'doing many things at once'
BTW, NO delay statements, your requirements tell you that.
Thank you for the inputs! I've never done ANY programming before and am tackling this all by myself as quickly as possible, so there's a few things I don't understand but will research to learn up on terminology and applications.
A lot of this was copy/paste from an AI request, but I really want to learn the actual language and be able to replicate this myself.
The LED's and resistors are just there (and in those values) to try to make the program do what I want it to do. I would not use those small values for real world application.
I see now that I haven't actually coded any buttons......oops......learning
The example posted by @LarryD, I don't understand fully, but I know it's because of my lack of programming knowledge and not because it's confusing. It seems simple enough looking at it, is it just stating to define actual descriptive states instead of the values associated with them?
I'd say that looks correct! is that schematic done with the IDE?
I see what you mean by the #define macro. I can use that to clearly indicate whatever task or information is needed instead of loosely defining based on the arduino's output/input, then implement the macro instead of typing everything that could be INSIDE the macro?
I'd say that looks correct! is that schematic done with the IDE? PCB design software was used to draw the schematic (mine is no longer available). There are free versions available, KICAD and EASY EDA
I see what you mean by the #define macro. I can use that to clearly indicate whatever task or information is needed instead of loosely defining based on the arduino's output/input, then implement the macro instead of typing everything that could be INSIDE the macro? Yes
Are the three schematics below effectively the same ?
Ask questions.
// S w i t c h e s a n d L E D s
// https://forum.arduino.cc/t/unwanted-delay-after-button-press-with-voltage-ladder/1365743
// SwitchesResistorLadderNetwork.ino
// Version YY/MM/DD Comments
// 1.00 25/03/20 Running code
// Notes:
//#define LEDon LOW //GPIO(Pin)---[220R]---A[LED]K---GND
//#define LEDoff HIGH
#define LEDon HIGH //+5V---[220R]---A[LED]K---GPIO/Pin
#define LEDoff LOW
#define PRESSED LOW //+5V---[Internal 50k]---PIN---[Switch]---GND
#define RELEASED HIGH
#define CLOSED LOW //+5V---[Internal 50k]---PIN---[Switch]---GND
#define OPENED HIGH
#define ENABLED true
#define DISABLED false
//Define the analog input pin (for the voltage ladder)
int analogValue;
int lastAnalog;
//Define the digital output pin
const byte LED1 = 3;
const byte LED2 = 4;
const byte LED3 = 5;
const byte LED4 = 6;
const byte heartbeatLED = 13;
//Define voltage thresholds for each switch (adjust as needed)
//Note: 5V = 1023
const int switch4treshhold = 0; //0.0v
const int switch3treshhold = 511; //2.5v Example: (511.0 * 5.0) / 1023.0 = 2.15v
const int switch2treshhold = 681; //3.3v
const int switch1treshhold = 767; //3.75
const int hysteresis = 50;
//timing stuff
unsigned long heartbeatTime;
unsigned long checkSwitchTime;
// s e t u p ( )
//Initialize serial communication for debugging (optional)
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
pinMode(LED4, OUTPUT);
pinMode(heartbeatLED, OUTPUT);
//read the current voltage on A0
lastAnalog = analogValue;
} //END of setup()
// l o o p ( )
//======================================================================== T I M E R heartbeat
//is it time to toggle the heartbeat LED ?
if (millis() - heartbeatTime >= 500ul)
//restart this TIMER
heartbeatTime = millis();
digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
//======================================================================== T I M E R check switches
//is it time to scan our switches ?
if (millis() - checkSwitchTime >= 50ul)
checkSwitchTime = millis();
checkSwitches();
// Other non blocking code goes here
} //END of loop()
// c h e c k S w i t c h e s ( )
void checkSwitches()
//has the voltage changed significantly since the last time we checked it ?
if (lastAnalog < (analogValue - hysteresis) || lastAnalog > (analogValue + hysteresis))
//update to this new value
Serial.print("\nAnalog Value = ");
Serial.print(analogValue);
Serial.print("\t");
Serial.print((analogValue * 5.0) / 1023.0);
Serial.println(" Volts");
//based on the new analog voltage, which button is pressed
if (analogValue < switch4treshhold + hysteresis)
Serial.println("Switch 4 Pressed");
//ledsOff();
//digitalWrite(LED4, !digitalRead(LED4));
digitalWrite(LED4, LEDon);
else if (analogValue < switch3treshhold + hysteresis)
//ledsOff();
//digitalWrite(LED3, !digitalRead(LED3));
digitalWrite(LED3, LEDon);
else if (analogValue < switch2treshhold + hysteresis)
//ledsOff();
//digitalWrite(LED2, !digitalRead(LED2));
digitalWrite(LED2, LEDon);
else if (analogValue < switch1treshhold + hysteresis)
//ledsOff();
//digitalWrite(LED1, !digitalRead(LED1));
digitalWrite(LED1, LEDon);
//no switch was pressed
ledsOff();
} //END of this switch
//======================================================================== nextSwitch
} //END of checkSwitches()
// l e d s O f f ( )
void ledsOff()
digitalWrite(LED4, LEDoff);
digitalWrite(LED3, LEDoff);
digitalWrite(LED2, LEDoff);
digitalWrite(LED1, LEDoff);
} //END of ledsOff()
every time, at 9600 baud. Don't just increase the baud, by the way, fix the problem.
Transmit nothing, or at least most a single Serial.println('.');
unless a button is newly pressed, at which time you should report the analog value to begin with - after that, then you'll need to explore debouncing techniques. Look at the StateChangeDetection example in the IDE for clues
Participation is necessary to converge on a solution. Always.
Out of curiosity, what in post #15 would have "scared them off", in your opinion? The explanation of serial constipation might not have been clear enough, but that should elicit a follow-on question, not silence.
