unwanted delay
The following code controls a looping pedal via midi and works as intended, except that there's a slight delay between pressing the pedal and the midi message being sent, meaning that I can't accurately loop in time. I can't see a debounce value of 20 millis being the cause, the midi message is the first thing inside each "case", is there anything else slowing it down?
// midi controller for line 6 M13 to control looper - solo OD
// apr 19
#include <MIDI.h>
#include <midi_Defs.h>
#include <midi_Message.h>
#include <midi_Namespace.h>
#include <midi_Settings.h>
MIDI_CREATE_DEFAULT_INSTANCE();
// Constants
#define SWITCH1 2 //rec
#define SWITCH2 3 // stop/ OD
#define SWITCH3 4 // play
#define SWITCH4 5 // stop
# define LED1 8
# define LED2 9
# define LED3 7
# define LED4 6
#define SWITCHES 4    // how many switches?
int switches[SWITCHES] = { SWITCH1, SWITCH2, SWITCH3, SWITCH4 };
int switchState[SWITCHES] = { LOW, LOW, LOW, LOW };   // Initial state of switch
int leds[SWITCHES] = { LED1, LED2, LED3, LED4 };
int currentSwitch = 0;
int thisLED = 0;
int activeLED = 0;
int ovrLED = 0;
int recording = 0; // state or recording
int ovr = 0;  // state of overdub
int solo = 0; // state of solo
int play = 0; // state of play
unsigned long SwitchMillis = 0; // when button was released
unsigned long DebounceMillis = 20; //
unsigned long CurrentMillis = 0;
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  pinMode(LED4, OUTPUT);
  MIDI.begin(1);
  // Setup Switches and activation LEDs
  for ( currentSwitch = 0; currentSwitch < SWITCHES; currentSwitch++ )
    pinMode( switches[currentSwitch], INPUT );          // Set pin for switch
    digitalWrite( switches[currentSwitch], HIGH );      // Turn on internal pullup
    pinMode( leds[currentSwitch], OUTPUT );             // Set pin for LED
  for ( int i = 0; i < 4; i++ ) // show it's ready
    for ( thisLED = 0; thisLED < SWITCHES; thisLED++ )
      digitalWrite( leds[thisLED], HIGH );
      delay(100);
      digitalWrite( leds[thisLED], LOW );
  CurrentMillis = millis();  // get the time at the start of this loop()
  if (CurrentMillis - SwitchMillis >= DebounceMillis)  //is it time to check the switches?
    SwitchMillis = millis(); //re-initilize Timer
      if ( (digitalRead(switches[currentSwitch]) != switchState[currentSwitch] ) && (switchState[currentSwitch] == HIGH) )
        switch ( currentSwitch )
          case 0: // rec or play
            if (recording == 0)
              MIDI.sendControlChange(50, 122, 1);
              lightPin(currentSwitch);
              recording = 1;
              MIDI.sendControlChange(28, 122, 1); // play
              lightPin(2); // switch play led on
              recording = 0;
              play = 1;
          case 1:  // solo or off
            if (solo == 0)
              MIDI.sendControlChange(11, 122, 1); // OD on
              lightPin(1);
              solo = 1;
              play = 1;
              MIDI.sendControlChange(28, 22, 1); // stop
              MIDI.sendControlChange(11, 0, 1); // OD off
              kill();
              solo = 0;
              play = 0;
          case 2: //  stop or play
            if (play == 0)
              play = 1;
              solo = 0;
              kill();
              recording = 0; // if recording, switch it off
              play = 0;
              solo = 0;
          case 3: // ovr or play
            if (ovr == 0)
              MIDI.sendControlChange(50, 10, 1);  // overdub
              lightPin(currentSwitch ); // switch stop led on
              ovr = 1;
              ovr = 0;
      } // end if changed
      switchState[currentSwitch] = digitalRead( switches[currentSwitch] );
    } // go thru switches
  } // end check switches
} // end loop
void lightPin( int activeLED )    // switch chosen LED on, others off
    if (activeLED == thisLED)
void kill()    // switch all LEDs off
You are debouncing 20msec every time CurrentMillis - SwitchMills is greater than 20ms regardless if any switch has changed value or not.
What you should be doing if constantly checking the switches and only IF one of them has changed, refresh your SwitchMills value to debounce the detected change.
