Unxepected unqualified-id before
I HAVE A PROBLEM OF THE SUBJECT BEFORE THE VOID LOOP , I HAVE ANOTHER SKETCH WITH ALMOST THE SAME CODE AND THAT PART IS THE SAME AND THE OTHER ONE IS READY TO UPLOAD AND THIS ONE NOT. DOES ANYONE KNOWS WHY?
#include <Wire.h>
#include <LiquidCrystal_PCF8574.h>
  //incluir las librerias
**//DEFINIR LOS PINES**
#define butUp    12
#define butDown  11
#define butP     10
#define butM      9
#define Lamp1    A0
#define Lamp2    A1
**//funciones auxiliares//**
void changeMenu();               //FUNCION PARA CAMBIAR DE MENU
void dispMenu();                 //FUNCION PARA MOSTRAR EL MENU ACTUAL
void scanauto();                //FUNCION MENU 1  , Intro
void temperatura();              //ejemplo
void activar_senal();            //FUNCION DE ACTIVAR SEÑAL
void menu4();                    //MENU LIBRE
**//variables globales//**
char menu = 1;                                       //variable para controlar menu
char set1 = 0, set2 = 0;                          //Control de lamparas, valor inicial 0
boolean t_butUp, t_butDown, t_butP, t_butM;             //booleans para botones
**//CONFIGURACION INICIAL//**
  disp.begin(20,4);                     // INICIAR LCD
  disp.setBacklight(255);               //PROGRAMAR LUZ DE FONDO
   for(char i=9; i<13; i++) pinMode(i, INPUT_PULLUP);     //PROGRAMAR COMO PULLUP
 pinMode(Lamp1, OUTPUT);                                //Configura LA SALIDA DEL PIN LAMP1
  pinMode(Lamp2, OUTPUT);                                //Configura LA SALIDA DEL PIN LAMP2
  t_butUp   = 0;                                      //DEFINE VALOR INICIAL DE LOS BOTONES
  t_butM    = 0;
  t_butP    = 0;
  t_butDown = 0;
  digitalWrite(Lamp1, LOW);                              //APAGADO AL INICIO
  digitalWrite(Lamp2, LOW);
  }//end setup
changeMenu();
dispMenu();
void changeMenu()                                       //Modifica MENU ACTUAL
   if(!digitalRead(butUp))   t_butUp   = 1;          //BOTON UP PRESIONADO? CAMBIAR VALOR
   if(!digitalRead(butDown)) t_butDown = 1;          //BOton DOWN PRESIONADO? CAMBAIR VALOR
   if(digitalRead(butUp) && t_butUp)                    //BOTON SUELTO Y VALOR YA CAMBIADO?
   {                                                    //ENTONCES
      t_butUp = 0;                                   //LIMPIAR VALOR
      disp.clear();                                     //LIMPIA DISPLAY
      menu++;                                           //INCREMENTA EL MENU
      if(menu > 4) menu = 1;                      //SI EL MENU ES MAYOR QUE 4 REGRESA AL 1
   } //end butUp
   if(digitalRead(butDown) && t_butDown)                //BOTON DOWN SUELTO Y VALOR YA CAMBIADO?
   {                                                    //ENTONCES
      t_butDown = 0;                                 //LIMPIA VALOR
      menu--;                                           //DECREMENTA MENU
      if(menu < 1) menu = 4;                      //SI  EL MENO ES MENOR QUE 1 IR AL MENU 4
   } //end butDown
} //end changeMenu
Care to explain that line? That is NOT how C or C++ defines comments.
i do it to make it more visible , but thanks i do it the right way and it seems to work. thank you. :)
