Thank you guys for your help! I searched online and found a counter code that counts up to 9 so i reversed it to count down from 9 to zero. But, I'm having trouble with double digits. But thank you for all the help! I do not take credit for the code because all i did was tweak it a little but so far this is what I have.
// G F + A B
// | | | | | -> pins and segments they control
// F| A |B
// |---G---| -> segments
// E| D |C
// E D + C DP
// Segments that make each number when lit:
// 0 => ABCDEF
// 1 => BC
// 2 => ABDEG
// 3 => ABCDG
// 4 => BCFG
// 5 => ACDFG
// 6 => ACDEFG
// 7 => ABC
// 8 => ABCDEFG
// 9 => ABCDFG
// Arduino digital pins used to light up
// corresponding segments on the LED display
#define A 2
#define B 3
#define C 4
#define D 5
#define E 6
#define F 7
#define G 8
#define GND1 9
#define GND2 10
// Pushbutton connected to pin 9
#define BUTTON 11
// Common anode;
// on when pin is low
// and off when pin is high
#define ON HIGH
#define OFF LOW
int count = 10; // current display count
int val = 0; // digital input from button
pinMode(A, OUTPUT);
pinMode(B, OUTPUT);
pinMode(C, OUTPUT);
pinMode(D, OUTPUT);
pinMode(E, OUTPUT);
pinMode(F, OUTPUT);
pinMode(G, OUTPUT);
pinMode(GND1, OUTPUT);
pinMode(GND2, OUTPUT);
pinMode(BUTTON, INPUT);
ten();
val = digitalRead(BUTTON);
if (val == HIGH) {
count--;
delay(300);
switch (count) {
case 0:
zero();
case 1:
one();
case 2:
two();
case 3:
three();
case 4:
four();
case 5:
five();
case 6:
six();
case 7:
seven();
case 8:
eight();
case 9: {
nine();
case 10:
ten();
count = -1;
// 0 => ABCDEF
void zero() {
digitalWrite(A, ON);
digitalWrite(B, ON);
digitalWrite(C, ON);
digitalWrite(D, ON);
digitalWrite(E, ON);
digitalWrite(F, ON);
digitalWrite(G, OFF);
digitalWrite(GND1, OFF);
// 1 => BC
void one() {
digitalWrite(A, OFF);
digitalWrite(D, OFF);
digitalWrite(E, OFF);
digitalWrite(F, OFF);
// 2 => ABDEG
void two() {
digitalWrite(C, OFF);
digitalWrite(G, ON);
// 3 => ABCDG
void three() {
// 4 => BCFG
void four() {
// 5 => ACDFG
void five() {
digitalWrite(B, OFF);
// 6 => ACDEFG
void six() {
// 7 => ABC
void seven() {
// 8 => ABCDEFG
void eight() {
// 9 => ABCDFG
void nine() {
digitalWrite(GND2, ON);
// 10=> 1.BC 2.ABCDEF
void ten() {
digitalWrite(GND1, ON);
digitalWrite(GND2, OFF);
delay(5);
