Up Key input does not work
arduino uno up Key input does not work,double setpoint = 76.12; The decimal point cannot be added or subtracted
#define DIN 8
#define CLK 3
#define LOAD 4
#define KEY_Position A1
#define KEY_UP A3
#define KEY_DW A2
#include "LedControl.h"
#define DIN 8 //DIN 12
#define CLK 3 //CLK 10
#define LOAD 4 //LOAD/CS 11
LedControl lc = LedControl(DIN, CLK, LOAD, 1);
long sht_temp;
long a, x, y, z, h;
long digito1, digito2, digito3, digito4, digito5, digito6, digito7, digito8;
int key_mode = 3;
long set_Setpoint;
void max7219_view()
sht_temp = setpoint * 100;
printC(sht_temp);
void MAX7219_Char()
delay(130);
lc.setChar(0, key_mode, ' ', 0); //void clearDisplay ( int * addr )
delay(130);
{ Serial.begin(9600);
pinMode(KEY_Position, INPUT);
pinMode(KEY_UP, INPUT);
pinMode(KEY_DW, INPUT);
digitalWrite(KEY_Position, HIGH);
digitalWrite(KEY_UP, HIGH);
digitalWrite(KEY_DW, HIGH);
lc.shutdown(0, false);
lc.setIntensity(0, 7);
lc.clearDisplay(0);
{ if (digitalRead(KEY_Position) == LOW)
key_mode ++;
if (key_mode >= 8)
key_mode = 3;
max7219_view();
set_Setpoint = setpoint * 100;
h = (set_Setpoint % 10) ;
z = (set_Setpoint / 10 ) % 10 ;
y = (set_Setpoint / 100 ) % 10 ;
x = (set_Setpoint / 1000 ) % 10 ;
a = (set_Setpoint / 10000 ) % 10 ;
if (!digitalRead(KEY_UP) and key_mode == 3) h += 1;
else if (!digitalRead(KEY_DW) and key_mode == 3) h -= 1;
else if (!digitalRead(KEY_UP) and key_mode == 4) z += 1;
else if (!digitalRead(KEY_DW) and key_mode == 4) z -= 1;
else if (!digitalRead(KEY_UP) and key_mode == 5) y += 1;
else if (!digitalRead(KEY_DW) and key_mode == 5) y -= 1;
else if (!digitalRead(KEY_UP) and key_mode == 6) x += 1;
else if (!digitalRead(KEY_DW) and key_mode == 6) x -= 1;
else if (!digitalRead(KEY_UP) and key_mode == 7) a += 1;
else if (!digitalRead(KEY_DW) and key_mode == 7) a -= 1;
if (h > 9) {
h = 0;
if (h < 0) {
h = 0;
if (z > 9) {
z = 0;
if (z < 0) {
z = 0;
if (y > 9) {
y = 0;
if (y < 0) {
y = 0;
if (x > 9) {
x = 0;
if (x < 0) {
x = 0;
if (a > 9) {
x = 0;
if (a < 0) {
x = 0;
long ttt = (a * 10000) + (x * 1000) + (y * 100) + (z * 10) + h;
setpoint = ttt ;
setpoint = setpoint / 100 ;
Serial.println(setpoint);
MAX7219_Char();
void printC( long sht_temp)
digito4 = (sht_temp % 10) ;
digito5 = (sht_temp / 10 ) % 10 ;
digito6 = (sht_temp / 100 ) % 10 ;
digito7 = (sht_temp / 1000 ) % 10 ;
digito8 = (sht_temp / 10000 ) % 10 ;
bit_dig();
void bit_dig()
lc.setDigit ( 0 , 7 , (byte) digito8, false);
lc.setDigit ( 0 , 6 , (byte) digito7, false);
lc.setDigit ( 0 , 5 , (byte) digito6, true);
lc.setDigit ( 0 , 4 , (byte) digito5, false);
lc.setDigit ( 0 , 3 , (byte) digito4, false);
proteus
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Before all that, you wrote a simple test sketch that just checked that your wiring was correct, and you could read the switches, and print some simple debug messages - does that still work?
