Up loading WEMOS DI MINI to Internet
Hi, could some one take a look at this sketch please. It is for Wi Fi connection of my WEMOS D1 MINI weather data gatherer. The problem I am having is this the sketch runs to the line -Serial.printin("HTTP server started") In the serial monitor it gets as far as WiFi connected..! Got IP: 192.168.1.131 - HTTP server started. then stops running no more info?? I am running a iMac PC.
#include <ESP8266WebServer.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME280 bme;
float temperature, humidity, pressure, altitude;
/*Put your SSID & Password*/
const char* ssid = "BT-98A8XZ";  // Enter SSID here
const char* password = "CVxPeA4KDNqLyC";  //Enter Password here
ESP8266WebServer server(80);
  bme.begin(0x76);
  Serial.println("Connecting to ");
  Serial.println(ssid);
  //connect to your local wi-fi network
  WiFi.begin(ssid, password);
  //check wi-fi is connected to wi-fi network
  Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected..!");
  Serial.print("Got IP: ");  Serial.println(WiFi.localIP());
  server.on("/", handle_OnConnect);
  server.onNotFound(handle_NotFound);
  server.begin();
  Serial.println("HTTP server started");
  server.handleClient();
void handle_OnConnect() {
  temperature = bme.readTemperature();
  humidity = bme.readHumidity();
  pressure = bme.readPressure() / 100.0F;
  altitude = bme.readAltitude(SEALEVELPRESSURE_HPA);
  server.send(200, "text/html", SendHTML(temperature,humidity,pressure,altitude));
void handle_NotFound(){
  server.send(404, "text/plain", "Not found");
String SendHTML(float temperature,float humidity,float pressure,float altitude){
  String ptr = "<!DOCTYPE html> <html>\n";
  ptr +="<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=no\">\n";
  ptr +="<title>ESP8266 Weather Station</title>\n";
  ptr +="<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}\n";
  ptr +="body{margin-top: 50px;} h1 {color: #444444;margin: 50px auto 30px;}\n";
  ptr +="p {font-size: 24px;color: #444444;margin-bottom: 10px;}\n";
  ptr +="</style>\n";
  ptr +="</head>\n";
  ptr +="<body>\n";
  ptr +="<div id=\"webpage\">\n";
  ptr +="<h1>ESP8266 Weather Station</h1>\n";
  ptr +="<p>Temperature: ";
  ptr +=temperature;
  ptr +="&deg;C</p>";
  ptr +="<p>Humidity: ";
  ptr +=humidity;
  ptr +="%</p>";
  ptr +="<p>Pressure: ";
  ptr +=pressure;
  ptr +="hPa</p>";
  ptr +="<p>Altitude: ";
  ptr +=altitude;
  ptr +="m</p>";
  ptr +="</div>\n";
  ptr +="</body>\n";
  ptr +="</html>\n";
  return ptr;
It is a server. It is waiting to serve. Connect to it with your web browser:
http://192.168.1.131/
Many thanks johnwasser, got that. Now I am trying to upload the data from the ESP 8266 to the Weather Underground, I have followed their instructions, and registered my details, their final instruction is to load certain details in to my software, I presume that's my IDE sketch ? or is it, can you help me further?
You are not the first person to want to upload weather data to Weather Underground from an ESP8266. Try a Google search to find some of the completed projects and use them to learn.
No disrespects but I have been doing this for days now.
But did you try a Google search?
Tom... :smiley: :+1: :coffee: :australia:
What details do they want you to add to your software?
I found a Raspberry Pi tutorial from 2017 that details how to use http GET requests to push data to Weather Underground. I would expect that that method is the same today. When you're logged into their site, do you see any documentation of that?
https://www.google.de/search?as_q=ESP+8266+the+Weather+Underground
https://www.google.de/search?q=ESP8266+upload+the+Weather+Underground
best regards Stefan
Yes, what words do you think I should use?
The ones Stefan used seemed to work pretty well.
I used: ESP8266 "Weather Underground"
Some of the projects were fetching data from Weather Underground but there were several uploading data.
don't stop there, who is Stefan?
StefanL38. Reply #8 came from him and looks to have some useful stuff.
Hi Stefan, I have attempted to load the sketch below from the one you recommended, but I keep getting an error message which say' there is no directory, new to me, I have downloaded Libraries, but directories?`Arduino: 1.8.13 (Mac OS X), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/User/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/User/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/User/Documents/Arduino/libraries -fqbn=esp8266:esp8266:d1_mini:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -vid-pid=0000_0000 -ide-version=10813 -build-path /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_621895 -warnings=none -build-cache /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_cache_784592 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mklittlefs.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mklittlefs-3.0.3-gcc10.3-9bcba0b.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.3-gcc10.3-9bcba0b.path=/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mkspiffs.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mkspiffs-3.0.3-gcc10.3-9bcba0b.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.python3.path=/Users/User/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=/Users/User/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -verbose /Users/User/Documents/Arduino/sketch_jul22b/sketch_jul22b.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/User/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/User/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/User/Documents/Arduino/libraries -fqbn=esp8266:esp8266:d1_mini:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -vid-pid=0000_0000 -ide-version=10813 -build-path /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_621895 -warnings=none -build-cache /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_cache_784592 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mklittlefs.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mklittlefs-3.0.3-gcc10.3-9bcba0b.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.3-gcc10.3-9bcba0b.path=/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mkspiffs.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mkspiffs-3.0.3-gcc10.3-9bcba0b.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.python3.path=/Users/User/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=/Users/User/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -verbose /Users/User/Documents/Arduino/sketch_jul22b/sketch_jul22b.ino
Using board 'd1_mini' from platform in folder: /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1
Using core 'esp8266' from platform in folder: /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1
Detecting libraries used...
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_621895/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_621895/sketch/sketch_jul22b.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
-> candidates: [ESP8266WiFi@1.0]
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_621895/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_621895/sketch/sketch_jul22b.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_621895/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_621895/sketch/sketch_jul22b.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for system_variables.h: []
ResolveLibrary(system_variables.h)
-> candidates: []
sketch_jul22b:9:10: fatal error: system_variables.h: No such file or directory
9 | #include "system_variables.h"
compilation terminated.
Using library ESP8266WiFi at version 1.0 in folder: /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi
Using library Wire at version 1.0 in folder: /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire
exit status 1
Invalid library found in /Users/User/Documents/Arduino/libraries/AM2320-1.1.3: no headers files (.h) found in /Users/User/Documents/Arduino/libraries/AM2320-1.1.3
you should post such long error-messages as code-section by using the <|> Button
No idea why this code needs a system_variables.h-file I don't have it on my system either. You should do a content-search for that filename through the files that are used in this project.
Or just don't compile it but look-up how the uploading to weather underground is done and just use this part of the code
best regards Stefan
Thanks Stefan, I have removed the line "system_variables" re run the sketch, I now get the following error.`Arduino: 1.8.13 (Mac OS X), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/User/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/User/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/User/Documents/Arduino/libraries -fqbn=esp8266:esp8266:d1_mini:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -vid-pid=0000_0000 -ide-version=10813 -build-path /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699 -warnings=none -build-cache /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_cache_784592 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mklittlefs.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mklittlefs-3.0.3-gcc10.3-9bcba0b.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.3-gcc10.3-9bcba0b.path=/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mkspiffs.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mkspiffs-3.0.3-gcc10.3-9bcba0b.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.python3.path=/Users/User/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=/Users/User/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -verbose /Users/User/Documents/Arduino/sketch_jul22b/sketch_jul22b.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/User/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/User/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/User/Documents/Arduino/libraries -fqbn=esp8266:esp8266:d1_mini:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -vid-pid=0000_0000 -ide-version=10813 -build-path /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699 -warnings=none -build-cache /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_cache_784592 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mklittlefs.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mklittlefs-3.0.3-gcc10.3-9bcba0b.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.3-gcc10.3-9bcba0b.path=/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mkspiffs.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mkspiffs-3.0.3-gcc10.3-9bcba0b.path=/Users/User/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.python3.path=/Users/User/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=/Users/User/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -verbose /Users/User/Documents/Arduino/sketch_jul22b/sketch_jul22b.ino
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/sketch/sketch_jul22b.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/sketch/sketch_jul22b.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/sketch/sketch_jul22b.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Adafruit_BME280.h: [Adafruit_BME280_Library-master@2.1.2]
ResolveLibrary(Adafruit_BME280.h)
-> candidates: [Adafruit_BME280_Library-master@2.1.2]
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/sketch/sketch_jul22b.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Adafruit_Sensor.h: [Adafruit_Unified_Sensor-1.1.4@1.1.4]
ResolveLibrary(Adafruit_Sensor.h)
-> candidates: [Adafruit_Unified_Sensor-1.1.4@1.1.4]
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/sketch/sketch_jul22b.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/sketch/sketch_jul22b.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/BearSSLHelpers.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/CertStoreBearSSL.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/ESP8266WiFi.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/ESP8266WiFiAP.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/ESP8266WiFiGeneric.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/ESP8266WiFiGratuitous.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/ESP8266WiFiMulti.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/ESP8266WiFiSTA-WPS.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/ESP8266WiFiScan.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/WiFiClient.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/WiFiServer.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/WiFiServerSecureBearSSL.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/WiFiUdp.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src/enable_wifi_at_boot_time.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire/Wire.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master/Adafruit_BME280.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4/Adafruit_Sensor.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI/SPI.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/sketch/sketch_jul22b.ino.cpp -o /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/preproc/ctags_target_for_gcc_minus_e.cpp -DARDUINO_LIB_DISCOVERY_PHASE
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/User/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/signing.py --mode header --publickey /Users/User/Documents/Arduino/sketch_jul22b/public.key --out /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core/Updater_Signing.h
/Users/User/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/lwip2/include -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/cores/esp8266 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/variants/d1_mini -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/ESP8266WiFi/src -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/Wire -I/Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master -I/Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4 -I/Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/sketch/sketch_jul22b.ino.cpp -o /var/folders/5f/04cvxqyn7gbgj88lgyctqdcw0000gp/T/arduino_build_678699/sketch/sketch_jul22b.ino.cpp.o
/Users/User/Documents/Arduino/sketch_jul22b/sketch_jul22b.ino: In function 'void ReadSensorInformation()':
sketch_jul22b:170:3: error: 'WU_humidity' was not declared in this scope
170 | WU_humidity = String(sensor_humidity,2);
sketch_jul22b:171:3: error: 'WU_baromin' was not declared in this scope
171 | WU_baromin = String(sensor_pressure,2);
sketch_jul22b:172:3: error: 'WU_tempf' was not declared in this scope
172 | WU_tempf = String(sensor_temperature);
Using library Adafruit_BME280_Library-master at version 2.1.2 in folder: /Users/User/Documents/Arduino/libraries/Adafruit_BME280_Library-master
Using library Adafruit_Unified_Sensor-1.1.4 at version 1.1.4 in folder: /Users/User/Documents/Arduino/libraries/Adafruit_Unified_Sensor-1.1.4
Using library SPI at version 1.0 in folder: /Users/User/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.1/libraries/SPI
exit status 1
gresleymanMANOFGRESLEY
use the <|>-Button to create a code-section!
this will make your posting SHORT
it is really annoying to post such long errormessages as plain text.
A code-section does two things:
1 keep all the information
2 making the posting short
you can re-edit your postings to do this
I'm not gonna analyse all the errors and wrong dependencies for you
if you are not willing to this analyses just drop the projekt and test the other one
Looks like some variable names were not declared, were mistyped, or were declared inside some other function. Maybe they were declared in "system_variables.h" but I have no idea why they would be.
StefanL38.
Many apologies, I thought I had done that, if you do not mind, I will try again, but if I fail, please do not be upset, I am trying. I have turned OFF "verbose output" in the IDE, does this help?
exit status 1
option enabled in File -> Preferences.
turning off verbose output reduces the number of lines. But this does not help because the interesting information might be no longer in the log.
So turn it on again. experts can search for the interesting term with the searchfunction of any editor
RE-edit your posting number #14 and #16 as a code-section
  • simply click on the pencil icon
  • mark all plain text
  • press Ctrl-X to cut out
  • click on the <|>-button
  • press Ctrl-V to paste clipboard-content again.
    best regards Stefan
