up the values
so ive created this code :
#include <Servo.h>
Servo testServo;
int pos = 0;
char w = "w";
char s = "s";
  testServo.attach(9);
  char rx_byte;
  if (Serial.available() > 0) {    // is a character available?
    rx_byte = Serial.read();       // get the character
    Serial.print("You typed: ");
    Serial.println(rx_byte);
    if(rx_byte == w)
      pos=pos+1;
    if(rx_byte == s)
      pos=pos-1;
    Serial.println(pos);
which suppose to up the pos variable by one if w is pressed, or lower it by 1 if s is pressed, im using arduino nano
originally i meant the pos to be up when pressing arrow up key and pos down by arrow down key, but couldnt check arrows (i think its better to see it in ASCI II but i forgot how xD so for now ill use w and s)
but those warnings shows up (and the code doesnt work)
G:\Arduino tests\sketch_jun23a\sketch_jun23a.ino:6:10: warning: invalid conversion from 'const char*' to 'char' [-fpermissive]
char s = "s";
anyone have any suggestion how can i check (in an if) what letter was pressed?
char w = "w";
should be
char w = 'w';
or use
if(rx_byte == 'w')
small but important difference
you coded
char w = "w";
double hyphens are to assign a string.
you use variable type char
chars are assigned using the single-hyphen
char w = 'w';
best regards Stefan
Clarification :
" is not a double hyphen it is a double quotation mark
' is not a single hyphen it is a single quotation mark
thanks all
worked like a charm
