UPD und Char to Char*
Hallo ich bin neu hier. Ich möchte Steuerbefehle über TCP/UDp an den Arduino Mega mit Ethernet Shield und DMX. Hab mich mit dem dem UPDSendReciveString versucht. Soweit läuft es auch nur es kommt ein Packet von irgendwo und dann läuft es nicht mehr.
#include <DmxSimple.h>
#include <SPI.h>         // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h>         // UDP library from: bjoern@cs.stanford.edu 12/30/2008
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 178, 210);
unsigned int localPort = 8888;      // local port to listen on
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
char  ReplyBuffer[] = "ack";       // a string to send back
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
  // start the Ethernet and UDP:
  Ethernet.begin(mac,ip);
  Udp.begin(localPort);
  DmxSimple.usePin(3);
  // if there's data available, read a packet
  int packetSize = Udp.parsePacket();
    if(packetSize)
    for(int i=0;i<UDP_TX_PACKET_MAX_SIZE;i++) packetBuffer[i] = 0;
    Serial.print("Received packet of size ");
    Serial.println(packetSize);
    Serial.print("From ");
    IPAddress remote = Udp.remoteIP();
    for (int i =0; i < 4; i++)
      Serial.print(remote[i], DEC);
      if (i < 3)
        Serial.print(".");
    Serial.print(", port ");
    Serial.println(Udp.remotePort());
    memset(packetBuffer, 0, UDP_TX_PACKET_MAX_SIZE);
    // read the packet into packetBufffer
    Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);
    Serial.println("Contents:");
    Serial.println(packetBuffer);
      char *ptr = packetBuffer;
      if (strncmp(ptr, "dmx", 3) == 0) {
      // get data (format: dmx000v000)
      char buff[5];
      memset(buff, 0, 5);
      // get channel
      strncpy (buff, &ptr[3], 3);
      int Channel = atoi(buff);
      // get value
      strncpy (buff, &ptr[7], 3);
      int value = atoi(buff);
      Serial.println(Channel);
      Serial.println(value);
      //DmxSimple.write(Channel,value)
    Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
    Udp.write(ReplyBuffer);
    Udp.endPacket();
  delay(10);
Hier die Ausgabe des Serial Monitors
Received packet of size 10
From 192.168.178.21, port 8888
Contents:
dmx000v000
0
0
Contents:
dmx000v000
0
0
Received packet of size -19967
From 118.32.48.32, port 49312
Contents:
Sobald eine andere IP auftaucht läuft es nicht mehr. Warum?
Wo kommt die IP her?
Ich habe auch versucht es über TCP (Chat Server) zulösen.
#include <SPI.h>
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = {
IPAddress ip(192,168,178, 210);
IPAddress gateway(192,168,178, 1);
IPAddress subnet(255, 255, 0, 0);
// telnet defaults to port 23
EthernetServer server(23);
boolean alreadyConnected = false; // whether or not the client was connected previously
  // initialize the ethernet device
  Ethernet.begin(mac, ip, gateway, subnet);
  // start listening for clients
  server.begin();
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Chat server address:");
  Serial.println(Ethernet.localIP());
  // wait for a new client:
  // when the client sends the first byte, say hello:
  if (client) {
    if (!alreadyConnected) {
      // clead out the input buffer:
      client.flush();
      Serial.println("We have a new client");
      client.println("Hello, client!");
      alreadyConnected = true;
      if (client.available() > 0) {
      // read the bytes incoming from the client:
      char thisChar = client.read();
      char *ptr = thisChar;
      char buff[5];
      memset(buff, 0, 5);
      // get channel
      // get value
      // echo the bytes back to the client:
      server.write(thisChar);
      // echo the bytes to the server as well:
      Serial.write(thisChar);
Aber ich bekomme den Client.read() nicht hin
char ptr = thisChar; (invalid conversion from ‘char’ to 'char’)
if (strncmp(ptr, “dmx”, 3) == 0) {
char buff[5];
memset(buff, 0, 5);
// get channel
// get value
vielleicht kann mir mal jemand einen Tip geben. A" warum beim UDP eine Andere IP kommt und sich der Arduino aufhängt. Und B wie man von char to char* convertiert.
So long
Squaredrone
Wie man von char to char* convertiert
Gar nicht. Da hat man was falsch verstanden. char* ist ein Zeiger auf ein (oder mehrere)char.
