Update 1.0.5 causing malfunctions
I was doing pretty well with a small sketch:
  Arduino Uno used for S-meter
  Temporarily printing to LCD
   The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int sensorPin = A0;
int sensorValue = 0;
float s_meter = 0.0;
// the setup routine runs once when you press reset:
  pinMode(A0, INPUT);
  analogReference(INTERNAL);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
// the loop routine runs over and over again forever:
  //read the value from A0
  sensorValue = analogRead(sensorPin);
  s_meter = (sensorValue * (1.1/1023)/22);
  lcd.setCursor(0,0);
  lcd.print(s_meter);
  delay(10000);
Then, the update notice appeared. I did the update, made some revisions and now the above no longer works.
It was giving me 0.50 on my lcd and now nothing happens. I checked and re-checked wiring and removed the
revisions I'd made. Unluckily, I hadn't saved the previous under another name. I'm using Windows XP Pro and
not having any problems with the upload.
Ron, KE5QDA
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
// pinMode(A0, INPUT); // <<<<<<<<<<<<<<<<<<<< Not necessary. Not appropriate. Remove it.
lcd.begin(16, 2);
Produces less code. Uses less SRAM. Correct definition...
const int sensorPin = A0;
  lcd.begin(16, 2);
  lcd.setCursor(0,0);
  lcd.print( "Hello, world!" );
Result is?
I get no result using this code.
If I turn my contrast control down, I get a row of solid 5x7 dots...second row, nothing.
Problem solved. A wire had slipped out and I placed it back in the wrong hole. My BAD!
Thanks for your help!!
You are welcome. I'm glad you have it working. (Reply #1 and #2 still apply. ;))
