Hello everyone,
I have a custom development board based on my prototype tests with mkr zero.
My board uses a SAMD21G18A as the MKR zero and a W5500 for ethernet connection.
The SAMD received commands via raw ethernet and proceeds based on these commands and send answers to my windows host program.
All working fine.
I read a lot on this topic about how to add the bootloader and output my code as hex or bin file.
Now I want to be able to update my code in the field without the need of a usb plug or any external software. My goal is to send the new code from the field computer to my SAMD via Ethernet and update it this way.
I already know that it is not possible to update the code directly. I had some ideas and want to ask some experts. For all ideas I run into the described problems or run out of informations:
Use some of the librarys which allow to access Flash as EEPROM and replace the files.
-> I did not find any information on how to access special areas in the Flash to replace the code.
Additionally I found conflicting information if the access to Flash is possible in this way. -
Use Ariadne to replace the code.
->I did not find any information that this bootloader can be used on the SAMD chips. -
Send my code to my controller during operation mode and store it on a external EEPROM or SD card. After Reboot the bootloader should check if new files are available and replace the old ones.
-> I did not find any information on this topic for MKR Zero. -
The bootloader should be able to communicate via the W5500 to receive an update and reboot after update. I would be able to send the data via raw ethernet or any other common ethernet protocol.
-> I Did not find any info for MKR Zero.
Does anyone has experience with that topic or has some helpful information?
Thanks in advance for any help...
Lutzer
