Update Library eHelath Sensor platform V2.0
Hi everyone
can anyone help me
I want to use the eHealth sensor platform V2.0 library, but the ehelath library is not readable in the Arduino application now
does anyone have a solution
or can anyone provide me the latest library of eHealth sensors
Hi @ralisarira
I'm not sure I understood correctly what you mean by this. Please provide a more detailed description to help me to understand it.
Make sure to include the full and exact text of any error or warning message you might have encountered.
the ehelath library is not detected by arduino software
the eHealth library available on the githup website and the libelium website is out of date for the current arduino version
That is too vague a description for me to be able to help you.
Maybe you think you are saving time by writing these very short posts, but I can assure you that is not so. If you would provide us with all the relevant information, it is likely we can provide you with a solution in a matter of minutes. Or we can spend days of frustrating back and forth trying to squeeze the information out of you. The choice of how this will go is yours to make.
Please remember that we can't see your computer. The only information we have is what you provide here.
this is the library that I use to use the eHelath sensor, but this library is not readable by the Arduino software
// include this library's description file
#include "eHealth.h"
// Accelerometer Variables and definitions						*
	//! not the wire library, can't use pull-ups
	#include "utils/i2c.h"
	//! Breakout board defaults to 1, set to 0 if SA0 jumper is set
	#define SA0 1
		#if SA0
			#define MMA8452_ADDRESS 0x1D  //! SA0 is high, 0x1C if low
		#else
			#define MMA8452_ADDRESS 0x1C
		#endif
	#define	int1Pin 2
	#define int2Pin 3
	//! Set the scale below either 2, 4 or 8.
	const byte scale = 2;
	//! Set the output data rate below. Value should be between 0 and 7.
	//! 0=800Hz, 1=400, 2=200, 3=100, 4=50, 5=12.5, 6=6.25, 7=1.56
	const byte dataRate = 0;
// Constructor of the class										*
	//! Function that handles the creation and setup of instances
	eHealthClass::eHealthClass(void) { /*void constructor*/ }
// Public Methods												*
	//!	Name:	initPositionSensor()												*
	//!	Description: Initializes the position sensor and configure some values.		*
	//!	Param : void																*
	//!	Returns: void																*
	//!	Example: eHealth.initPositionSensor();										*
	void eHealthClass::initPositionSensor(void)
		byte c;
		/* Set up the interrupt pins, they're set as active high, push-pull */
		pinMode(int1Pin, INPUT);
		digitalWrite(int1Pin, LOW);
		pinMode(int2Pin, INPUT);
		digitalWrite(int2Pin, LOW);
		/* Read the WHO_AM_I register, this is a good test of communication */
		c = readRegister(0x0D);  // Read WHO_AM_I register
		if (c == 0x2A)	{ // WHO_AM_I should always be 0x2A
			initMMA8452(scale, dataRate);  // init the accelerometer if communication is good
			Serial.println("MMA8452Q is online...");
			Serial.print("Could not connect to MMA8452Q: 0x");
			Serial.println(c, HEX);
			//while (1);  // Loop forever if communication doesn't happen
	//!	Name:	readBloodPressureSensor()											*
	//!	Description: Initializes the BloodPressureSensor sensor.					*
	//!	Param : void																*
	//!	Returns: void																*
	//!	Example: eHealth.initBloodPressureSensor();									*
	void eHealthClass::readBloodPressureSensor(void)
		unsigned char _data;
		int ia=0;
		length=0;
		Serial.begin(19200);
	 	Serial.write(0xAA);
		delayMicroseconds(1);
	 	Serial.write(0x55);
		Serial.write(0x88);
	 	delay(2500);
		Serial.print("\n");
		if (Serial.available() > 0) { // The protocol sends the measures
			for (int i = 0; i<4; i++){ // Read four dummy data
				Serial.read();
 			while(_data != 0xD1){
  				if (ia==0){
   				_data = Serial.read();
			bloodPressureDataVector[length].year = swap(_data);
			bloodPressureDataVector[length].month = swap(Serial.read());
			bloodPressureDataVector[length].day = swap(Serial.read());
			bloodPressureDataVector[length].hour = swap(Serial.read());
			bloodPressureDataVector[length].minutes = swap(Serial.read());
			bloodPressureDataVector[length].systolic = swap(Serial.read());
			bloodPressureDataVector[length].diastolic = swap(Serial.read());
			bloodPressureDataVector[length].pulse = swap(Serial.read());
			length++;
			ia=1;
			for (int i = 0; i<4; i++){ // CheckSum 1
				Serial.read();
 			for (int i = 0; i<3; i++){ // CheckSum 2
  				Serial.read();
	//!		Name:	initPulsioximeter()												*
	//!		Description: Initializes the pulsioximeter sensor.						*
	//!		Param : void															*
	//!		Returns: void															*
	//!		Example: eHealth.initPulsioximeter();									*
	void eHealthClass::initPulsioximeter(void)
		// Configuring digital pins like INPUTS
		pinMode(13, INPUT);		pinMode(12, INPUT);
		pinMode(11, INPUT);		pinMode(10, INPUT);
		pinMode( 9, INPUT);		pinMode( 8, INPUT);
		pinMode( 7, INPUT);		pinMode( 6, INPUT);
		// attach a PinChange Interrupt to our pin on the rising edge
	//!		Name:	getTemperature()												*
	//!		Description: Returns the corporal temperature.							*
	//!		Param : void															*
	//!		Returns: float with the corporal temperature value.						*
	//!		Example: float temperature = eHealth.getTemperature();					*
	float eHealthClass::getTemperature(void)
		//Local variables
		float Temperature; //Corporal Temperature
		float Resistance;  //Resistance of sensor.
		float ganancia=5.0;
		float Vcc=3.3;
		float RefTension=3.0; // Voltage Reference of Wheatstone bridge.
		float Ra=4700.0; //Wheatstone bridge resistance.
		float Rc=4700.0; //Wheatstone bridge resistance.
		float Rb=821.0; //Wheatstone bridge resistance.
		int sensorValue = analogRead(A3);
		float voltage2=((float)sensorValue*Vcc)/1023; // binary to voltage conversion
		// Wheatstone bridge output voltage.
		voltage2=voltage2/ganancia;
		// Resistance sensor calculate
		float aux=(voltage2/RefTension)+Rb/(Rb+Ra);
		Resistance=Rc*aux/(1-aux);
		if (Resistance >=1822.8) {
			// if temperature between 25ºC and 29.9ºC. R(tª)=6638.20457*(0.95768)^t
			Temperature=log(Resistance/6638.20457)/log(0.95768);
			if (Resistance >=1477.1){
					// if temperature between 30ºC and 34.9ºC. R(tª)=6403.49306*(0.95883)^t
					Temperature=log(Resistance/6403.49306)/log(0.95883);
				if (Resistance >=1204.8){
					// if temperature between 35ºC and 39.9ºC. R(tª)=6118.01620*(0.96008)^t
					Temperature=log(Resistance/6118.01620)/log(0.96008);
				else{
					if (Resistance >=988.1){
						// if temperature between 40ºC and 44.9ºC. R(tª)=5859.06368*(0.96112)^t
						Temperature=log(Resistance/5859.06368)/log(0.96112);
					else {
						if (Resistance >=811.7){
							// if temperature between 45ºC and 50ºC. R(tª)=5575.94572*(0.96218)^t
							Temperature=log(Resistance/5575.94572)/log(0.96218);
		return Temperature;
	//!		Name:	getOxygenSaturation()											*
	//!		Description: Returns the oxygen saturation in blood in percent.			*
	//!		Param : void															*
	//!		Returns: int with the oxygen saturation value							*
	//!		Example: int SPO2 = eHealth.getOxygenSaturation();						*
	int eHealthClass::getOxygenSaturation(void)
		return SPO2;
	//!		Name:	getBPM()														*
	//!		Description: Returns the heart beats per minute.						*
	//!		Param : void															*
	//!		Returns: int with the beats per minute									*
	//!		Example: int BPM = eHealth.getBPM();									*
	int eHealthClass::getBPM(void)
		return BPM;
	//!		Name:	getSkinConductance()											*
	//!		Description: Returns the value of skin conductance.						*
	//!		Param : void															*
	//!		Returns: float with the value of skin conductance						*
	//!		Example: float conductance = eHealth.getSkinConductance();				*
	float eHealthClass::getSkinConductance(void)
		// Local variable declaration.
		float resistance;
		float conductance;
		delay(1);
		// Read an analogic value from analogic2 pin.
		float sensorValue = analogRead(A2);
		float voltage = sensorValue*5.0/1023;
		conductance = 2*((voltage - 0.5) / 100000);
		// Conductance calculation
		resistance = 1 / conductance;
		conductance = conductance * 1000000;
		delay(1);
		if (conductance > 1.0) 	return conductance;
		else return -1.0;
	//!		Name:	getSkinResistance()												*
	//!		Description: Returns the value of skin resistance.						*
	//!		Param : void															*
	//!		Returns: float with the value of skin resistance						*
	//!		Example: float resistance = eHealth.getSkinResistance();				*
	float eHealthClass::getSkinResistance(void)
		float resistance;
		float conductance;
		float voltage = (sensorValue * 5.0) / 1023;
		delay(2);
		//Conductance calcultacion
		delay(2);
		if (resistance > 1.0 ) return resistance;
		else return -1.0;
	//!		Name:	getSkinConductanceVoltage()										*
	//!		Description: Returns the skin conductance value in voltage .			*
	//!		Param : void															*
	//!		Returns: float with the skin conductance value in voltage 				*
	//!		Example: float volt = eHealth.getSkinConductanceVoltage();				*
	float eHealthClass::getSkinConductanceVoltage(void)
		delay(2);
		//Read analogic value from analogic2 pin.
		int sensorValue = analogRead(A2);
		//Convert the readed value to voltage.
		float voltage = ( sensorValue * 5.0 ) / 1023;
		delay(2);
		return voltage;
	//!		Name:	getECG()														*
	//!		Description: Returns an analogic value to represent the ECG.			*
	//!		Param : void															*
	//!		Returns: float with the ECG value in voltage			 				*
	//!		Example: float volt = eHealth.getECG();									*
	float eHealthClass::getECG(void)
		float analog0;
		// Read from analogic in.
		analog0=analogRead(0);
		return analog0 = (float)analog0 * 5 / 1023.0;
	//!		Name:	getEMG()														*
	//!		Description: Returns an analogic value to represent the EMG.			*
	//!		Param : void															*
	//!		Returns: float with the EMG value in voltage			 				*
	//!		Example: float volt = eHealth.getEMG();									*
	int eHealthClass::getEMG(void)
		int analog0;
		return analog0;
	//!		Name:	getBodyPosition()												*
	//!		Description: Returns the current body position.							*
	//!		Param : void															*
	//!		Returns: uint8_t with the the position of the pacient.	 				*
	//!		Example: uint8_t position = eHealth.getBodyPosition();					*
	uint8_t eHealthClass::getBodyPosition(void)
		static byte source;
		/* If int1 goes high, all data registers have new data */
		if (digitalRead(int1Pin)) {// Interrupt pin, should probably attach to interrupt function
			readRegisters(0x01, 6, &data[0]);  // Read the six data registers into data array.
			/* For loop to calculate 12-bit ADC and g value for each axis */
			for (int i=0; i<6; i+=2) {
				accelCount[i/2] = ((data[i] << 8) | data[i+1]) >> 4;  // Turn the MSB and LSB into a 12-bit value
					if (data[i] > 0x7F) {
						accelCount[i/2] = ~accelCount[i/2] + 1;
						accelCount[i/2] *= -1;  // Transform into negative 2's complement #
				accel[i/2] = (float) accelCount[i/2]/((1<<12)/(2*scale));  // get actual g value, this depends on scale being set
		/* If int2 goes high, either p/l has changed or there's been a single/double tap */
		if (digitalRead(int2Pin)) {
			source = readRegister(0x0C);  // Read the interrupt source reg.
			if ((source & 0x10)==0x10)  // If the p/l bit is set, go check those registers
				portraitLandscapeHandler();
			delay(50); // Delay here for a little printing visibility, make it longer, or delete it
		delay(100);
		return bodyPos;
	//!		Name:	getSystolicPressure()											*
	//!		Description: Returns the  value of the systolic pressure.				*
	//!		Param : void															*
	//!		Returns: int with the systolic pressure.								*
	//!		Example: int systolic = eHealth.getSystolicPressure();					*
	int eHealthClass::getSystolicPressure(int i)
		return bloodPressureDataVector[i].systolic;
	//!		Name:	getDiastolicPressure()											*
	//!		Description: Returns the  value of the diastolic pressure.				*
	//!		Param : void															*
	//!		Returns: int with the diastolic pressure.								*
	//!		Example: int diastolic = eHealth.getDiastolicPressure();				*
	int eHealthClass::getDiastolicPressure(int i)
		return bloodPressureDataVector[i].diastolic;
	//!		Name:	getAirFlow()													*
	//!		Description: Returns an analogic value to represent the air flow.		*
	//!		Param : void															*
	//!		Returns: int with the airFlow value (0-1023).							*
	//!		Example: int airFlow = eHealth.getAirFlow();							*
	int eHealthClass::getAirFlow(void)
		int airFlow = analogRead(A1);
		return airFlow;
	//!		Name:	printPosition()													*
	//!		Param : uint8_t position : the current body position. 					*
	//!		Returns: void															*
	//!		Example: eHealth.printPosition(position);								*
	void eHealthClass::printPosition( uint8_t position )
		if (position == 1) {
			Serial.println("Prone position");
		} else if (position == 2) {
			Serial.println("Stand or sit position");
		} else if (position == 3) {
			Serial.println("Left lateral decubitus");
		} else if (position == 4) {
			Serial.println("Supine position");
		} else if (position == 5) {
			Serial.println("Rigth lateral decubitus");
		} else  {
			Serial.println("non-defined position");
	//!		Name:	readPulsioximeter()												*
	//!		Description: It reads a value from pulsioximeter sensor.				*
	//!		Param : void										 					*
	//!		Returns: void															*
	//!		Example: readPulsioximeter();											*
	void eHealthClass::readPulsioximeter(void)
		uint8_t digito[41];
		uint8_t A = 0;
		uint8_t B = 0;
		uint8_t C = 0;
		uint8_t D = 0;
		uint8_t E = 0;
		uint8_t F = 0;
		uint8_t G = 0;
		for (int i = 0; i<41 ; i++) { // read all the led's of the module
			A = !digitalRead(13);
			B = !digitalRead(12);
			C = !digitalRead(11);
			D = !digitalRead(10);
			E = !digitalRead(9);
			F = !digitalRead(8);
			G = !digitalRead(7);
			digito[i] = segToNumber(A, B, C ,D ,E, F,G);
			delayMicroseconds(300); //300 microseconds
			SPO2 = 10 * digito[25] + digito[20];
			BPM  = 100 * digito[19] + 10 * digito[2] + digito[0];
	//!		Name: airflowWave()														*
	//!		Description: It prints air flow wave form in the serial monitor			*
	//!		Param : int air with the analogic value									*
	//!		Returns: void															*
	//!		Example: eHealth.airflowWave();											*
	void eHealthClass::airFlowWave(int air)
		for (int i=0; i < (air / 5) ; i ++) {
				Serial.print("..");
		Serial.print("..");
		Serial.print("\n");
		delay(25);
	//!		Name: readGlucometer()													*
	//!		Description: It reads the data stored in the glucometer					*
	//!		Param : void															*
	//!		Returns: void															*
	//!		Example: eHealth.readGlucometer();										*
	void eHealthClass::readGlucometer(void)
		delay(100);
		Serial.begin(1200);
		delay(100);
		pinMode(5, OUTPUT);
		digitalWrite(5, HIGH);
		delay(10);
		Serial.write("U"); // Start communication command.
		delay(1000); // Wait while receiving data.
		Serial.print("\n");
			length = Serial.read();// The protocol sends the number of measures
			Serial.read(); // Read one dummy data
			for (int i = 0; i<length; i++) { // The protocol sends data in this order
				glucoseDataVector[i].year = Serial.read();
				glucoseDataVector[i].month = Serial.read();
				glucoseDataVector[i].day = Serial.read();
				glucoseDataVector[i].hour = Serial.read();
				glucoseDataVector[i].minutes = Serial.read();
				Serial.read(); // Byte of separation must be 0x00.
				glucoseDataVector[i].glucose = Serial.read();
				glucoseDataVector[i].meridian = Serial.read();
				Serial.read(); // CheckSum 1
				Serial.read(); // CheckSum 2
		digitalWrite(5, LOW);
	//!		Name: getGlucometerLength()												*
	//!		Description: it returns the number of data stored in the glucometer		*
	//!		Param : void															*
	//!		Returns: uint8_t with length											*
	//!		Example: int length = eHealth.getGlucometerLength();					*
	uint8_t eHealthClass::getGlucometerLength(void)
		return length;
	//!		Name: getBloodPressureLength()											*
	//!		Description: it returns the number of data stored in					*
	//!		the blood pressure sensor												*
	//!		Param : void															*
	//!		Example: int length = eHealth.getBloodPressureLength();					*
	uint8_t eHealthClass::getBloodPressureLength(void)
		return length;
	//!		Name: numberToMonth()													*
	//!		Description: Convert month variable from numeric to character.			*
	//!		Param : int month in numerical format									*
	//!		Returns: String with the month characters (January, February...).		*
	//!		Example: Serial.print(eHealth.numberToMonth(month));					*
	String eHealthClass::numberToMonth(int month)
		if (month == 1)  return "January";
		else if (month == 2)  return "February";
		else if (month == 3)  return "March";
		else if (month == 4)  return "April";
		else if (month == 5)  return "May";
		else if (month == 6)  return "June";
		else if (month == 7)  return "July";
		else if (month == 8)  return "August";
		else if (month == 9)  return "September";
		else if (month == 10) return "October";
		else if (month == 11) return "November";
		else return "December";
	//!		Name:	version()														*
	//!		Description: It check the version of the library						*
	//!		Param : void															*
	//!		Returns: void															*
	//!		Example: eHealth.version();												*
	int eHealthClass::version(void)
		return 2.0;
// Private Methods												*
	//! This function will read the p/l source register and
	//!	print what direction the sensor is now facing */
	void eHealthClass::portraitLandscapeHandler()
		byte pl = readRegister(0x10);  // Reads the PL_STATUS register
		switch((pl&0x06)>>1)  // Check on the LAPO[1:0] bits
			case 0:
				position[0] = 0;
			case 1:
				position[0] = 1;
			case 2:
				position[0] = 2;
			case 3:
				position[0] = 3;
		if (pl&0x01)  // Check the BAFRO bit
			position[1] = 0;
			position[1] = 1;
		if (pl&0x40)  // Check the LO bit
			position[2] = 0;
			position[2] = 1;
		bodyPosition();
	//! Initialize the MMA8452 registers.
	void eHealthClass::initMMA8452(byte fsr, byte dataRate)
		MMA8452Standby();  // Must be in standby to change registers
		/* Set up the full scale range to 2, 4, or 8g. */
		if ((fsr==2)||(fsr==4)||(fsr==8))
			writeRegister(0x0E, fsr >> 2);
			writeRegister(0x0E, 0);
		/* Setup the 3 data rate bits, from 0 to 7 */
		writeRegister(0x2A, readRegister(0x2A) & ~(0x38));
		if (dataRate <= 7)
			writeRegister(0x2A, readRegister(0x2A) | (dataRate << 3));
		/* Set up portrait/landscap registers */
		writeRegister(0x11, 0x40);  // Enable P/L
		writeRegister(0x13, 0x14);  // 29deg z-lock,
		writeRegister(0x14, 0x84);  // 45deg thresh, 14deg hyst
		writeRegister(0x12, 0x05);  // debounce counter at 100ms
		/* Set up single and double tap */
		writeRegister(0x21, 0x7F);  // enable single/double taps on all axes
		writeRegister(0x23, 0x20);  // x thresh at 2g
		writeRegister(0x24, 0x20);  // y thresh at 2g
		writeRegister(0x25, 0x8);  // z thresh at .5g
		writeRegister(0x26, 0x30);  // 60ms time limit, the min/max here is very dependent on output data rate
		writeRegister(0x27, 0x28);  // 200ms between taps min
		writeRegister(0x28, 0xFF);  // 1.275s (max value) between taps max
		/* Set up interrupt 1 and 2 */
		writeRegister(0x2C, 0x02);  // Active high, push-pull
		writeRegister(0x2D, 0x19);  // DRDY int enabled, P/L enabled
		writeRegister(0x2E, 0x01);  // DRDY on INT1, P/L on INT2
		MMA8452Active();  // Set to active to start reading
	//! Sets the MMA8452 to standby mode. It must be in standby to change most register settings.
	void eHealthClass::MMA8452Standby()
		byte c = readRegister(0x2A);
		writeRegister(0x2A, c & ~(0x01));
	//! Sets the MMA8452 to active mode. Needs to be in this mode to output data
	void eHealthClass::MMA8452Active()
		writeRegister(0x2A, c | 0x01);
	//! Read i registers sequentially, starting at address into the dest byte array.
	void eHealthClass::readRegisters(byte address, int i, byte * dest)
		i2cSendStart();
		i2cWaitForComplete();
		i2cSendByte((MMA8452_ADDRESS<<1));	// write 0xB4
		i2cSendByte(address);	// write register address
		i2cSendStart();
		i2cSendByte((MMA8452_ADDRESS<<1)|0x01);	// write 0xB5
		for (int j=0; j<i; j++) {
			i2cReceiveByte(TRUE);
			dest[j] = i2cGetReceivedByte();	// Get MSB result
		i2cSendStop();
		cbi(TWCR, TWEN);// Disable TWI
		sbi(TWCR, TWEN);// Enable TWI
	//! Read a single byte from address and return it as a byte.
	byte eHealthClass::readRegister(uint8_t address)
		byte data;
		i2cSendStart();
		i2cSendStart();
		data = i2cGetReceivedByte();	// Get MSB result
		i2cSendStop();
		cbi(TWCR, TWEN);	// Disable TWI
		sbi(TWCR, TWEN);	// Enable TWI
		return data;
	//! Writes a single byte (data) into address
	void eHealthClass::writeRegister(unsigned char address, unsigned char data)
		i2cSendStart();
		i2cSendByte((MMA8452_ADDRESS<<1));// write 0xB4
		i2cSendByte(address);// write register address
		i2cSendByte(data);
		i2cSendStop();
	//! Assigns a value depending on body position.
	void eHealthClass::bodyPosition( void )
		if (( position[0] == 0 ) && (position[1] == 1) && (position [2] == 0)) {
			bodyPos = 1;
		} else if (( position[0] == 1 ) && (position[1] == 1) && (position [2] == 0)) {
			bodyPos = 1;
		} else if (( position[0] == 3 ) && (position[1] == 1) && (position [2] == 0)) {
			bodyPos = 1;
		} else if (( position[0] == 2 ) && (position[1] == 0) && (position [2] == 0)) {
			bodyPos = 5;
		} else if (( position[0] == 2 ) && (position[1] == 1) && (position [2] == 1)) {
			bodyPos = 5;
		} else if (( position[0] == 2 ) && (position[1] == 1) && (position [2] == 0)) {
			bodyPos = 1;
		} else if (( position[0] == 0 ) && (position[1] == 1) && (position [2] == 1)) {
			bodyPos = 2;
		} else if (( position[0] == 0 ) && (position[1] == 0) && (position [2] == 1)) {
			bodyPos = 2;
		} else if (( position[0] == 1 ) && (position[1] == 1) && (position [2] == 1)) {
			bodyPos = 3;
		} else if (( position[0] == 1 ) && (position[1] == 0) && (position [2] == 1)) {
			bodyPos = 3;
	    } else if (( position[0] == 3 ) && (position[1] == 0) && (position [2] == 1)) {
			bodyPos = 3;
		} else if (( position[0] == 3 ) && (position[1] == 1) && (position [2] == 1)) {
			bodyPos = 3;
		} else if (( position[0] == 1 ) && (position[1] == 0) && (position [2] == 0)) {
			bodyPos = 4;
		} else if (( position[0] == 3 ) && (position[1] == 0) && (position [2] == 0)) {
			bodyPos = 4;
		//} else if (( position[0] == 3 ) && (position[1] == 0) && (position [2] == 1)) {
		//	bodyPos = 5;
		//} else if (( position[0] == 3 ) && (position[1] == 1) && (position [2] == 1)) {
		//	bodyPos = 5;
		} else if (( position[0] == 2 ) && (position[1] == 0) && (position [2] == 1)) {
			bodyPos = 5;
		} else  {
			bodyPos = 6;
	//! Converts from 7 segments to number.
	uint8_t eHealthClass::segToNumber(uint8_t A, uint8_t B, uint8_t C, uint8_t D, uint8_t E, uint8_t F, uint8_t G )
		if ((A == 1) && (B == 1) && (C == 1) && (D == 0) && (E == 1) && (F == 1) && (G == 1)) {
			return 0;
		} else if ((A == 0) && (B == 1) && (C == 0) && (D == 0) && (E == 1) && (F == 0) && (G == 0)) {
			return 1;
		} else if ((A == 1) && (B == 1) && (C == 0) && (D == 1) && (E == 0) && (F == 1) && (G == 1)) {
			return 2;
		} else if ((A == 1) && (B == 1) && (C == 0) && (D == 1) && (E == 1) && (F == 0) && (G == 1)) {
			return 3;
		} else if ((A == 0) && (B == 1) && (C == 1) && (D == 1) && (E == 1) && (F == 0) && (G == 0)) {
			return 4;
		} else if ((A == 1) && (B == 0) && (C == 1) && (D == 1) && (E == 1) && (F == 0) && (G == 1)) {
			return 5;
		} else if ((A == 1) && (B == 0) && (C == 1) && (D == 1) && (E == 1) && (F == 1) && (G == 1)) {
			return 6;
		} else if ((A == 1) && (B == 1) && (C == 0) && (D == 0) && (E == 1) && (F == 0) && (G == 0)) {
			return 7;
		} else if ((A == 1) && (B == 1) && (C == 1) && (D == 1) && (E == 1) && (F == 1) && (G == 1)) {
			return 8;
		} else if ((A == 1) && (B == 1) && (C == 1) && (D == 1) && (E == 1) && (F == 0) && (G == 1)) {
			return 9;
		} else  {
			return 0;
	//! Swap data for blood pressure mesure
	char eHealthClass::swap(char _data)
		char highBits = (_data & 0xF0) / 16;
 		char lowBits =  (_data & 0x0F) * 16;
  		return ~(highBits + lowBits);
// Preinstantiate Objects										*
	eHealthClass eHealth = eHealthClass();
do you have a link for this ?
so this directory is not structured according to Arduino's library format guidelines.
so you'll have to mess around with adding the relevant files to your project probably
that's the problem
I'm looking for the latest library of the sensor I hope someone has it and
seems the latest commit was 10 years ago... feels like an abandoned piece of code....
Which sensor are you looking at driving?
I use the eHelath v2.0 sensor platform which was purchased by my lecturer in 2014
I've no clue what this is but it seems possibly obsolete...
thank you for the response
I will try to improve the existing library
have a nice day
and thank you all for answering my question
I hope there is still someone who can help me through my question in the future
Maybe you could Look at the individual components of the kit and see if there are dedicated libraries
