I have two Arduino's and want to communicate some integers between them.
But when I check if RHDatagram::available(), It is always false for both the transmitter and the receiver.
My code for the transmitter
#include <RHDatagram.h>
#include <RH_ASK.h>
#include <SPI.h>
#define CLIENT_ADDRESS 1
#define SERVER_ADDRESS 0
RH_ASK driver;
RHDatagram manager(driver, CLIENT_ADDRESS);
struct dataStruct{
int integerX = 0;
int integerY = 1;
int integerZ = 2;
unsigned long counter = 0;
}myData;
byte buf[sizeof(myData)] = {0};
if (manager.init())
Serial.print("manager initiated");
}else{
Serial.print("INIT FAILED");
sendValues();
void sendValues()
byte zize=sizeof(myData);
memcpy(buf, &myData, zize);
int i = 0;
while(i<4)
if (manager.sendto(buf, zize, SERVER_ADDRESS))
Serial.print("message sent");
}else{
Serial.print("SENDTO() FAILED");
i++;
myData.counter = myData.counter + 1;
Serial.print("Transmission number: ");
Serial.println(myData.counter);
and for the receiver
#include <RH_ASK.h>
#include <SPI.h>
//#define CLIENT_ADDRESS 2
RH_ASK driver;
RHDatagram manager(driver, SERVER_ADDRESS);
struct dataStruct{
int integerX = 7;
int integerY = 7;
int integerZ = 7;
}myData;
if (manager.init())
}else{
receiveValues();
void receiveValues()
uint8_t buf[sizeof(myData)];
uint8_t from;
uint8_t len = sizeof(buf);
if (manager.available())
if (manager.recvfrom(buf, &len, &from))
memcpy(&myData, buf, sizeof(myData));
Serial.print("--------------------------------------------");
Serial.print("Got message from unit: ");
Serial.println(from, DEC);
Serial.print("");
Serial.print("integerX: ");
Serial.println(myData.integerX);
Serial.print("integerY: ");
Serial.println(myData.integerY);
Serial.print("integerZ: ");
Serial.println(myData.integerZ);
thank you in advance
UPDATE:
As far as I can see, code works and transmits data to the pins but I can't make sure if the kit supports my code and idk why. Will test with an oscilloscope if the transmitter produces any signal.
Still manager.available() gives false though, removing it from the manager.recvfrom() part does the job.
