Hi! I have an Arduino Uno (AtMega328). Is possible to write to the board's memory?
Basically, I want to receive compiled sketch bytes via BLE, and write to the board's memory. Then, at the end, press Reset.
There is a bootloader that allows this, at least with BLE?
- Not everybody will understand right away what BLE stands for, so if you are using abbreviations, explain them at least once (here: BLE = Bluetooth Low Energy)
- Every Arduino comes with 3 types of memory; one of them is: EEPROM; the Uno has 1k EEPROM on board
Here is a link to get you more information about the memory types and sizes:
You can read and write to the EEPROM (but not more than about 100.000 cycles).
But I suspect that this is not enough for your entire code (full sketch, if I understood you correctly). And: you want to get it into the "normal" memory to execute the code afterwards, don't you?
Mightbe you could use an SD card to store the sketch and a boot up routine which then reads first the content of the SD card with the code. But I am just guessing; use the forum's search if others have already succeeded with that kind of code shuffling.
