Im preparing to build a project that needs to operate with a pc but is autonomous in its operations so if the PC crashes it can handle it self gracefully.
It involves PWM curves based on external sensors for light control. Originally I had the pc handling the math, taking in the sensor readings, making decisions based on those readings and then sending out text strings to interactively control PWM changes, using the Arduino as an extension of the pc, but if the pc crashed or froze so did the unit.
In my new design I want to only use the pc to update the program/light cues and then the Arduino goes on its merry way, although it will continue to send serial updates back to the computer for status. all sensor and control is autonomous in the Arduino, as it should be.
The problem I am facing is this is to be used by end users, so the program front end I am writing for the choreography of the light cues is artist friendly but I dont want to make them also be Arduino tech savy and do raw sketch IDE interaction.
In other words I want to write a program that creates a sketch with the end user just choosing things like red light, set it to fade %60 over X seconds if you see sensor x get input and so on.
Then once the sketch is generated, (no coding by the end user) I want them to be able to push a software button that says Commit Cues to Controller and it uploads the new sketch resets and runs, with out the extra step of having them use the regular Arduino IDE and sketch loading process.
Any program/hardware stubs, code snippets supporting circuits or ideas along these lines ?
The whole goal is that the end user doesn't really interact with the Arduino directly as we do, but as a controller extension.
Does any of this make sense?
Thanks in advance for any ideas or help.
BOZ
