void updateSensor(void)
SensorRaw = analogRead(A0);
Sensor = map(SensorRaw, 0, 1023, 0, 500);
Serial1.print("n0.val=");
Serial1.print(Sensor);
Serial1.write(0xff); // We always have to send this three lines after each command sent to the nextion display.
Dear all, looking for the way to only send the "Sensor" value to the Serial1 only if it gets higher or lower than the current value by set amount.
The current amount will always be exactly equal to the current amount, won't it?
If you want to send data only when the current amount differs from the PREVIOUS amount by more than some amount, you need to keep track of the previous amount, and then:
Keeps sending all the time, not sure wheres the bug, also slowed the transfer drastically.
int previousValue;
Sensor = analogRead(A0);
Sensor = map(Sensor, 0, 1023, 0, 500);
if (abs(Sensor - previousValue) > 5) {
previousValue = Sensor;
Serial.println(Sensor);
It would help a lot if you posted your whole program or a smaller but complete program that shows the problem
Sure sorry
#include "Nextion.h"
NexButton b0 = NexButton(0, 1, "button0");
NexButton b1 = NexButton(0, 2, "button1");
NexDSButton bt0 = NexDSButton(0, 3, "bt0");
NexPage page0 = NexPage(0, 0, "page0"); // Page added as a touch event
NexPage page1 = NexPage(1, 0, "page1"); // Page added as a touch event
NexPage page2 = NexPage(2, 0, "page2"); // Page added as a touch event
int DS1 = 0;// dual state starts deselected
int CurrentPage = 0;
int SensorRaw = 0;
int Sensor = 0;
NexTouch *nex_listen_list[] =
&b0,
&b1,
&bt0,
&page0, // Page added as a touch event
&page1, // Page added as a touch event
&page2, // Page added as a touch event
NULL
void bt0PopCallback(void *ptr)
uint32_t dual_state;
NexDSButton *btn = (NexDSButton *)ptr;
bt0.getValue(&dual_state);
if (dual_state)
DS1 = 1;
DS1 = 0;
Serial.print("DualState1 = ");
Serial.println(DS1);
// Page change event:
void page0PushCallback(void *ptr) // If page 0 is loaded on the display, the following is going to execute:
CurrentPage = 0; // Set variable as 0 so from now on arduino knows page 0 is loaded on the display
} // End of press event
void page1PushCallback(void *ptr) // If page 1 is loaded on the display, the following is going to execute:
CurrentPage = 1; // Set variable as 1 so from now on arduino knows page 1 is loaded on the display
void page2PushCallback(void *ptr) // If page 2 is loaded on the display, the following is going to execute:
CurrentPage = 2; // Set variable as 2 so from now on arduino knows page 2 is loaded on the display
////////////////////////// End of touch events
pinMode(A0, INPUT);
nexInit();
b0.attachPush(b0PushCallback); //button press
b0.attachPop(b0PopCallback); // button release
b1.attachPush(b1PushCallback); //button press
b1.attachPop(b1PopCallback); // button release
bt0.attachPop(bt0PopCallback, &bt0); // dual state
page0.attachPush(page0PushCallback); // Page press event
page1.attachPush(page1PushCallback); // Page press event
page2.attachPush(page2PushCallback); // Page press event
nexLoop(nex_listen_list);
//Serial.print("Page# = ");
//Serial.println(CurrentPage);
if (CurrentPage == 1) {
updateSensor();
// Serial.println(SensorVal);
void b0PushCallback(void *ptr)
Serial.println("B0 is Pressed");
void b0PopCallback(void *ptr)
Serial.println("B0 is Released");
void b1PushCallback(void *ptr)
Serial.println("B1 is Pressed");
void b1PopCallback(void *ptr)
Serial.println("B1 id Released");
int previousValue;
//Serial.println(Sensor);
If this is the current value, shouldn't the previous value variable be declared somewhere real close to here?
Should the current value variable and the previous value variable have similar names, so one can see that they ARE related?
Yes you are correct.
code corrected
int SensorRaw = 0;
int SensorCurrentValue = 0;
int SensorPreviousValue;
&b0,
&b1,
&bt0,
NULL
if (dual_state)
DS1 = 1;
DS1 = 0;
pinMode(A0, INPUT);
nexInit();
updateSensor();
SensorCurrentValue = analogRead(A0);
SensorCurrentValue = map(SensorCurrentValue, 0, 1023, 0, 500);
if (abs(SensorCurrentValue - SensorPreviousValue) > 5) {
SensorPreviousValue = SensorCurrentValue;
Serial1.print("n1.val=");
Serial1.print(SensorCurrentValue);
if (abs(SensorCurrentValue - SensorPreviousValue) > 2) {
Serial1.print(SensorPreviousValue);
Serial.println(SensorPreviousValue);
Works as desired, but as you may notice, i`m sending the SensorPreviusValue
At the time you send the value, SensorCurrentValue and SensorPreviousValue contain the same value, so it doesn't matter which you send. I'd think that sending the current value would be the obvious thing to do, though.
