Just a quick note to let you know that there are a few updates on Arduino Create
You can always check the Bell icon in the upper right corner of create-staging.arduino.cc for more updates and notifications.
Serial Monitor is now faster on Windows, and has an improved performance on older PCs and on Firefox
A few UI fixes (last line of code is not truncated anymore!)
We are really close to fully support HTTPS and the Arduino/Genuino 101, we are going to post on this thread as soon as these new features will be available.
Yesterday we deployed a new version of both the deamon and the server code. What you get now is full HTTPS support (both on server and agent) and many other improvements.
Arduino/Genuino 101 is now supported and we improved our way to deploy. It means we can release much faster and you will have an updated version more often.
we just deployed a new version of the web application.
We improved the libraries and examples search. Libraries and examples are now automatically filtered according to the current board selected. Searching in the examples sidebar now gives results also from the subfolders.
We migrated Arduino Project Hub from create-staging.arduino.cc/projecthub to create.arduino.cc/projecthub,
tomorrow we will also implement and automatic redirect.
Yesterday we updated our plugin, please let us know if it was not automatically updated to the latest (1.0.25-092da5b) or if you encounter any problem.
Sorry for the temporarily unavailability of the Web Editor this morning. We took a little bit longer than expected but now everything is back online!
As reported in the email we sent you, here the main updates:
Each sketch you create on the Arduino Web Editor will have a unique URL, this is the first step to allow you to share sketches and access them online as you would do in Google Docs
We hugely improved the security of the Arduino Plugin, it can now only communicates with the Arduino Create page, no other site
We finally implemented the tab scaling! You can now display sketches with a lot of tabs and be able to access them all
A lot of small UX/UI improvements
We are working really hard to support Safari, we are almost done so keep tight
Since the update on the Arduino Plugin was pretty big, if for any reason it is not working try to:
Click on the Plugin tray icon, press Pause and then press Open again
You can also relaunch the Plugin as you would do with any application on your PC
@mamu, there are still some bugs on iPad: you cannot close the Sketchbook panel for instance. If you find any please open a separate topic and list them all. Thanks!
Hi!
We have some great news for Maker Faires San Mateo:
You can import your Sketchbook via a .zip file!
Whatβs more, sharing a sketch is now as easy as sharing a link. (See here for an example of how a public shared sketch looks like.)
My first experience was disappointing as I could not manage to open a sketch I have on my PC .
It actually only imports the first tab but not all the other 20 tabs that where in the sketch.I gave up doing it manually.
Robert
