Updating code from tutorial: combi-button lock
I want to re-create a project from a tutorial that I found but the sketch needs to be updated bc it was made at least 5 years ago, and there are error messages. In the comment section of this tutorial people have expressed this same issue with it. The project is a lock but instead of a key pad it uses 4 buttons. The LEDs act as the lock mechanism in the tutorial.
The tutorial link is: https://www.instructables.com/id/Arduino-Combi-button-Lock/?ALLSTEPS
The code (for the actual bread board version, but the ios/Android hook up) is:
/* a simple passcode lock for Arduino, using 4 buttons,
* created by Sam White, known as s-j-whitey on Instructables and
* samwhiteUK just about everywhere else!!
* I hope soon to be samwhiteUK on Instructables as well, so if
* you can't find me under the name s-j-whitey then you know
* where I'll be!!
* All serial commands in this sketch are for debugging only, do not
* feel like the Arduino must be connected to the PC, i.e. power
* could be drawn from a wall outlet or batteries.
* The system can be reset after a correct attempt by a push of the
* reset button on the Arduino board itself
const int button1 = 8; //first button is on pin 8
const int button2 = 9; //second is on pin 9
const int button3 = 10; //third is pin 10
const int button4 = 11; //fourth is pin 11
const int redLed = 4; //red LED is on pin 4
const int greenLed = 12; //green LED is pin 12
int code[] = {1,2,3,4}; //the desired code is entered in this array,
//separated by commas
int entered[4]; //create a new empty array for the code entered by
//the user (has 4 elements)
void setup(){ //run once at sketch startup
Serial.begin(9600); //begin Serial
pinMode(button1, INPUT); //button 1 is an input
pinMode(button2, INPUT); //button 2 is an input
pinMode(button3, INPUT); //button 3 is an input
pinMode(button4, INPUT); //button 4 is an input
pinMode(redLed, OUTPUT); //the red LED is an output
pinMode(greenLed, OUTPUT); // the green LED is an output
setupLights(); //run the setupLights routine
setupLights(); //run it again
delay(650); //delay (only for effect, :P not needed)
digitalWrite(redLed, HIGH); //turn the red LED on
for (int i = 0; i < 4;i++){ //work through numbers 0-3
Serial.println(code[i]); //print each digit of the code
Serial.println(entered[i]); //print each element of the entered[]
//array (this was for me to check that it
//started at 0
void loop(){ //run repeatedly
if (digitalRead(button1) == HIGH){ //if button1 is pressed
checkEntered1(1); //call checkEntered and pass it a 1
delay(250);//wait, needed for correct functioning, otherwise
//buttons are deemed to be pressed more than once
else if (digitalRead(button2) == HIGH){ //if button2 is pressed
checkEntered1(2); //call checkEntered1 and pass it a 2
delay(250); //wait
else if (digitalRead(button3) == HIGH){ //if button3 is pressed
checkEntered1(3); //call checkEntered1 and pass it a 3
delay(250); //wait
else if (digitalRead(button4) == HIGH){ //if button4 is pressed
checkEntered1(4); //call checkEntered1 and pass it a 4
delay(250); //wait
void checkEntered1(int button /* define the 1,2,3 or 4 as an integer called button
*/){ //check the first element of the entered[] array
if (entered[0] != 0){ //if it is not a zero, i.e. it has already been inputted
checkEntered2(button); //move on to checkEntered2, passing it "button"
else if(entered[0] == 0){ //if it is zero, i.e. if it hasn't been defined with a
button yet
entered[0] = button; //set the first element as the button that has been
pressed
Serial.print("1: ");Serial.println(entered[0]); //for debugging
void checkEntered2(int button){ //check the second element of the entered[] array
if (entered[1] != 0){ //if it is not a zero, i.e. it has already been inputted
checkEntered3(button); //move on to checkEntered3, passing it "button"
else if(entered[1] == 0){ //if it is zero, i.e. if it hasn't been defined with a
button yet
entered[1] = button; //set the second element as the button that has been
pressed
Serial.print("2: ");Serial.println(entered[1]); //for debugging
void checkEntered3(int button){ //check the third element of the entered[] array
if (entered[2] != 0){ //if it is not a zero, i.e. it has already been inputted
checkEntered4(button); //move on to checkEntered4, passing it "button"
else if (entered[2] == 0){ //if it is zero, i.e. if it hasn't been defined with
a button yet
entered[2] = button; //set the third element as the button that has been
pressed
Serial.print("3: ");Serial.println(entered[2]); //for debugging
void checkEntered4(int button){ //check the fourth element of the entered[] array
if (entered[3] == 0){ //if it is zero, i.e. if it hasn't been defined with a
button yet
entered[3] = button; //set the final element as the button that has been
pressed
Serial.print("4: ");Serial.println(entered[3]); //for debugging
delay(100); //allow time for processing
compareCode(); //call the compareCode function
void compareCode(){ //checks if the code entered is correct by comparing the
code[] array with the entered[] array
for (int i = 0; i<4;i++){ //these three lines are for debugging
Serial.println(entered[i], BYTE);
if ((entered[0]==code[0]) && (entered[1]==code[1]) && (entered[2]==code[2]) &&
(entered[3]==code[3])){ //if all the elements of each array are equal
digitalWrite(redLed, LOW); // turn the red LED off
digitalWrite(greenLed, HIGH); //turn the green LED on
delay(100); //wait for a bit
digitalWrite(greenLed, LOW); //turn the green LED off
loop(); //return to loop() (not really necessary)
else { //if you (or the intruder) get the code wrong
flash(); //call the flash function
for (int i = 0; i < 4; i++){ //this next loop is for debugging
entered[i] = 0;
void flash(){ // this is basically the blink example, look at that for an
explantion of this, I wont insult your intelligence... oh wait, I already did that
earlier when explaining the green LED flashing... sorry 'bout that
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
void setupLights(){ // a funky display run at reset
digitalWrite(redLed, HIGH); //turn both
digitalWrite(greenLed, HIGH); //LEDs on
delay(75); //wait
digitalWrite(redLed, LOW); //turn them
digitalWrite(greenLed, LOW); //off again
delay(75); //wait
And the errors are:
Arduino: 1.8.1 (Linux), Board: “Arduino/Genuino Uno”
/home/paul/Arduino/keypad_project/keypad_project.ino: In function ‘void loop()’:
keypad_project:54: error: ‘checkEntered1’ was not declared in this scope
keypad_project:59: error: ‘checkEntered1’ was not declared in this scope
keypad_project:63: error: ‘checkEntered1’ was not declared in this scope
keypad_project:67: error: ‘checkEntered1’ was not declared in this scope
compareCode()’:
keypad_project:120: error: expected ‘;’ before ‘ln’
Serial.write ln(entered*, BYTE);*
keypad_project:120: error: statement cannot resolve address of overloaded function
exit status 1
I also want to know how I would convert this to power a motor instead of LEDs, should I post that to a different topic more to do with hardware?
Something strange happened with the lines in that code. It’s been put through an editor or something that inserted extra newlines on some of the long lines. This split some comments so that words that were meant to be comments ended up on lines of their own.
The only ‘compatibility’ I changed was BYTE to BIN on one Serial.println(). Now it compiles. I haven’t tested it.
I also used the CTRL-T formatter on it to fix up the missing indentation.
  where I'll be!!
int code[] = {1, 2, 3, 4}; //the desired code is entered in this array,
void setup() { //run once at sketch startup
  for (int i = 0; i < 4; i++) { //work through numbers 0-3
    //started at 0
void loop() { //run repeatedly
  if (digitalRead(button1) == HIGH) { //if button1 is pressed
  else if (digitalRead(button2) == HIGH) { //if button2 is pressed
    delay(250); //wait
  else if (digitalRead(button3) == HIGH) { //if button3 is pressed
    delay(250); //wait
  else if (digitalRead(button4) == HIGH) { //if button4 is pressed
    delay(250); //wait
void checkEntered1(int button ) { //check the first element of the entered[] array
  if (entered[0] != 0) { //if it is not a zero, i.e. it has already been inputted
  else if (entered[0] == 0) { //if it is zero, i.e. if it hasn't been defined with a    button yet
    entered[0] = button; //set the first element as the button that has been    pressed
    Serial.print("1: "); Serial.println(entered[0]); //for debugging
void checkEntered2(int button) { //check the second element of the entered[] array
  if (entered[1] != 0) { //if it is not a zero, i.e. it has already been inputted
  else if (entered[1] == 0) { //if it is zero, i.e. if it hasn't been defined with a    button yet
    entered[1] = button; //set the second element as the button that has been    pressed
    Serial.print("2: "); Serial.println(entered[1]); //for debugging
void checkEntered3(int button) { //check the third element of the entered[] array
  if (entered[2] != 0) { //if it is not a zero, i.e. it has already been inputted
  else if (entered[2] == 0) { //if it is zero, i.e. if it hasn't been defined with    a button yet
    entered[2] = button; //set the third element as the button that has been    pressed
    Serial.print("3: "); Serial.println(entered[2]); //for debugging
void checkEntered4(int button) { //check the fourth element of the entered[] array
  if (entered[3] == 0) { //if it is zero, i.e. if it hasn't been defined with a    button yet
    entered[3] = button; //set the final element as the button that has been    pressed
    Serial.print("4: "); Serial.println(entered[3]); //for debugging
void compareCode() { //checks if the code entered is correct by comparing the  code[] array with the entered[] array
  for (int i = 0; i < 4; i++) { //these three lines are for debugging
    Serial.println(entered[i], BIN);
  if ((entered[0] == code[0]) && (entered[1] == code[1]) && (entered[2] == code[2]) &&
      (entered[3] == code[3])) { //if all the elements of each array are equal
    for (int i = 0; i < 4; i++) { //this next loop is for debugging
      entered[i] = 0;
void flash() { // this is basically the blink example, look at that for an explantion of this, I wont insult your intelligence... oh wait, I already did thatearlier when explaining the green LED flashing... sorry 'bout that
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
void setupLights() { // a funky display run at reset
  delay(75); //wait
  delay(75); //wait
