WIN10 64b
IDE vers 1.8.13
Firmware version installed: 1.3.0
Latest firmware version available : 1.4.1
I tried several times to update but I always get in the windows that should show the latest firmware the NINA 1.3.0
After "upgrade" it stay at 1.3.0
WiFiNINA firmware check.:
Check result: NOT PASSED
The firmware version on the module do not match the
version required by the library, you may experience
issues or failures.
Hi @alains. The NINA firmware is distributed with the Arduino IDE. There have been several releases of the NINA firmware since the Arduino IDE 1.8.13 release. An easy way to get NINA firmware version 1.4.1 is to install the hourly build of the Arduino IDE, which you can download for free from this page:
Then just run that version of the Arduino IDE and do the normal firmware update process.
The nightly build is primarily intended to be used for beta testing, so I'm not necessarily recommending that you switch to using it as your primary version of the Arduino IDE. You are welcome to go back to using Arduino IDE 1.8.13 as soon as you have updated the firmware.
Pert:
I did the firmware update with the IDE hourly build: After some errors during the download, freezing the computer, but repeating 4 times the process, I was able to get the 1.4.1 update.
Thanks for your help!
