Hi! to all, I want to blink a LED using ESP32 PWM pin at frequency 5 Hz (which can be updated in loop section when required) and duty cycle 50%. PWM generation part of my program is here-
#include <Arduino.h>
#include <driver/ledc.h>
int freq = 0;
int channel = 0;
int resolution = 8;
const int pwmChannel = 0; // LEDC channel for PWM
const int pwmPin = 26; // PWM output pin
const int sig_duty = 1; // cyclacity of 1/2 or 50% 1 is 50% or 1/2^1
ledcSetup(channel, freq, resolution);
ledcAttachPin(pwmPin, channel);
// Configure LEDC PWM
ledcSetup(pwmChannel, 0, 8); // LEDC channel 0, frequency 0Hz, 8-bit resolution
ledcAttachPin(pwmPin, pwmChannel); // Attach LEDC channel to pin
// Update LEDC PWM frequency
ledcWriteTone(pwmChannel, 5);
This code is getting compile but LED connected on pin 26 is not blinking at all. Please help to find out the problem with code. Thanks in advance for any help.
// Forum: https://forum.arduino.cc/t/updating-frequency-at-pwm-pin/1247368
// This Wokwi project: https://wokwi.com/projects/395088728070574081
const int pwmChannel = 1;
pinMode(pwmPin, OUTPUT);
// Is the frequency used ?
// Can the frequency be anything ?
ledcSetup(pwmChannel, 32, 8);
Try it in Wokwi simulation:
I did not try to find why your sketch does not work, and this one does. I used normal code and removed everything that was in the way. I think that the delay(1000); in the loop() makes it work.
Thanks for your reply and solution but my code is a part of a long program and blocking code will cause hindrance in execution. Also, I have to take trials by changing duty cycle by hard code.
Then you have to find another way for the ledcWriteTone(). If the frequency of the led is changed only once every few seconds, then only call ledcWriteTone() when the frequency is changed.
If the ledcWriteTone() was a perfect function, then it would allow to be called that often and it would smoothly transit from one frequency to another. But it is not perfect. I think that the timer for the PWM is reset every time the function is called.
Under the Arduino layer is a FreeRTOS layer. You could create a task to blink the led.
With millis() it is easy to blink the led 5 times per second. That is the most simple solution.
OK, Thanks. I am changing frequency using HMI. Every time new frequency is received from HMI it get updated at pin26 but duty cycle is remaining same even on changing value in const int sig_duty = 1; // cyclacity of 1/2 or 50% 1 is 50% or 1/2^1. Can you please help to change duty cycle in hard code.
Do you want to make a dimmed blinking led with 50% duty cycle ? Or a blinking led that is either fully on or fully off with variable duty cycle ? Or a dimmed blinking led that blinks with a variable duty cycle ?
There are many tutorials and examples and libraries for ledc. Even the ledc itself has functions that are rarely used, such as a automatic fade. There is even a "ledc_update_duty()" function, I never heard of that before.
Thanks for reply. I will choose final duty cycle (e.g. 10% or 15% which gives better results) after trials and will hard code the same and this will not be changed during running the code. Frequency changes when ever data is received from HMI. I am using sig_duty = 1; // cyclacity of 1/2 or 50% 1 is 50% or 1/2^1 as shown in the code above but that is not working.
Check if the following solution serves your purpose while FressRTOS based multi-tasking version is being prepared.
// the number of the LED pin
const int ledPin = 26; // 26 corresponds to GPIO2
// setting PWM properties
const int freq = 5; //Hz
const int ledChannel = 0;
const int resolution = 8;
Serial.println("Hello");
// configure LED PWM functionalitites
ledcSetup(ledChannel, freq, resolution);
// attach the channel to the GPIO to be controlled
ledcAttachPin(ledPin, ledChannel);
byte dutyCycle = 128;
ledcWrite(ledChannel, dutyCycle);//LED blinks at 5 Hz with 50% dutyCycle
Thanks for reply. Using this code LED blinks at freq = 5 and above. I can change duty cycle by replacing 128 in byte dutyCycle = 128;
Can you please suggest how to update freq while code is running if freq = a decimal number received from HMI. Also, can you please help to visualize above code using Wokwi serial plotter.
OK thanks.
On using ledc_set_freq() funtion to update frequency compiler is throwing error as - Compilation error: invalid conversion from 'int' to 'ledc_mode_t' [-fpermissive]
My code is as under-
// Event Occurs when response comes from HMI
void onHMIEvent(String address, int lastByte, String message, String response){
Serial.println("OnEvent : [ A : " + address + " | D : "+ String(lastByte, HEX)+ " | M : "+message+" | R : "+response+ " ]");
String myString = ""+ String(lastByte, DEC)+ "";
int myInt = myString.toInt();
Serial.println(myInt);
ledc_set_freq(myInt)
ledcWrite(Channel, 10);
Serial.print(" Frequency: ");
Serial.println(myInt); // Print current frequency
Please help to find out the reason of error.
Thanks in advance.
First of all thanks for your help.
I have re-arranged my code lines as suggested by you. Now code is as
ledcSetup(Channel, myInt, resolution);
ledcAttachPin(26, Channel);
delay(10); // Adjust delay as needed for responsiveness
Now facing a new problem, I am getting current frequency printed in serial monitor on increasing/decreasing it from HMI. But in actual, on increasing frequency it is increasing on PWM pin but not decreasing on decreasing, although serial monitor prints decreased value. It means that frequency is changing in upward direction but not in downward direction.
Also, serial monitor is printing an error.
OnEvent : [ A : 52005200 | D : 0 | M : | R : 5a a5 83 52 00 01 00 05 5a a5 83 52 00 01 00 00 ]
0
E (57427) ledc: freq_hz=0 duty_resolution=8
Frequency: 0
Please help to resolve.
The following steps could be carried out to dynamically change the frequency of the PWM signal from the InputBox of Serial Monitor (Fig-1): 1. Upload the following sketch into ESP32 Dev Board.
char myData[10];
ledcWrite(ledChannel, dutyCycle);//50% dutyCycle;
byte n = Serial.available();
if (n != 0)
byte m = Serial.readBytesUntil('\n', myData, sizeof myData - 1);
myData[m] = '\0'; //null charcater
byte myFreq = atoi(myData);
ledcSetup(ledChannel, myFreq, resolution);
2. Check that LED is blinking at 5 Hz with 50% duty cycle. 3. Open Serial Monitor (SM) with Newline option and Bd = 115200. 4. Enter 10 in the InputBox and click on the Send Button of SM. 5. Check that LED blinks at 10 Hz. 6. If you wish, you can also change the duty cycle from the InputBox of SM.
Thanks. Now I can increase or decrease frequency using your code of declaration part. But frequency is not going below 5. On sending a digit below 5 or 0 previous value remains as it is and serial monitor shows error as- E (37639) ledc: freq_hz=0 duty_resolution=8.
