Updating time clock via serial port
Hi I have a problem trying to update my time clock via serial port < the rest of the functions LCD display and time track are working correct but my code does not update the serial time sent, any suggestions
// include the library code:
#include <LiquidCrystal.h>
#include <Time.h>
// to set the time bytes
char timeString[7]; // create a string to hold the time value when it's read
int seconds_ones;
int minutes_ones;
int hours_ones;
int seconds_tens;              // Initialise values for tens and ones units of h,m,s
int minutes_tens;              // these are the values actually sent to the LEDs
int hours_tens;
//volatile unsigned char tick;
unsigned char seconds = 0;
unsigned char minutes = 58;     // Inititialise actual values for h,m,s
unsigned char hours = 23;
int hours_increase = 0;
int mins_increase = 0;
int val = 0;            // to adjust the clock
long time = 0;
// try to get serial in out
char incomingByte;              // for incoming serial data
char inString[]= "0000000";
int i = 0 ;
int T = 84; // ASCII T
int D = 68; //asccii D
int t = 116; // ascci t
// initialize the library with the numbers of the interface pins
//LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
  // start serial port at 9600 bps:
  // set up the LCD's number of rows and columns:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print(" MY TIME IS    ");
   i=0; // reset the array index
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 8):
lcd.setCursor(8, 1);  // here the time is displayed on the LCD
//this is a polling routine to get MY_time serial out
if ((Serial.available() >0) && (Serial.read() == t)) {
   //if(Serial.read() == t) ;          // to inquire the time
   Serialtime_out();
 if(Serial.read() == 'T ') { // wait for 7 characters
   for (int i=0; i < 7; i++) {
      timeString[i] = Serial.read(); // reach each time string character into a character array
if (timeString[0]=='T') {
         hours_tens= (timeString[1]);
         hours_ones = (timeString[2]);
         minutes_tens = (timeString[3]) ;
         minutes_ones = (timeString[4]);
         seconds_tens= (timeString[5]);
         seconds_ones= (timeString[6]);
//// to test that the T123456 was store properly waiting for D to dump
if ((Serial.available() >0) && (Serial.read() == D)){          // to inquire the time
       //   Serial.print(inString);
       //  Serial.print(inString[1], BYTE);
       //  Serial.print(inString[2], BYTE);
       //  Serial.print(inString[3], BYTE);
       //  Serial.print(inString[4], BYTE);
       //  Serial.print(inString[5], BYTE);
       //  Serial.print(inString[6], BYTE);
         //Serial.print(inString[6], BYTE
     Serial.flush();             // clear the buffer
      seconds ++ ;
      My_time ();             // 24 hour format keep displayed
// lcd display of time
  lcd.print(hours_tens);
  lcd.print(hours_ones);
  lcd.print(":");
  lcd.print(minutes_tens);
  lcd.print(minutes_ones);
  lcd.print(":");
  lcd.print(seconds_tens);
  lcd.print(seconds_ones);
void My_time () {               // Function to display the time
    seconds_ones = seconds % 10;           // Get the 1's digit of seconds
    if (seconds>=10){                      // If seconds greater than 10
     seconds_tens = seconds / 10;}         // Get 10's digit of seconds
    else {
      seconds_tens = 0;}                   // Otherwise 10s is 0
// to adjust the more than 60
 if (seconds>=60){                      // If seconds greater than 10
    // seconds_tens = seconds / 10;}         // Get 10's digit of seconds
    //else {
        seconds_ones = 0;
      seconds_tens = 0;
        seconds = 0 ;                   // Otherwise 10s is 0
        minutes ++ ;}                   // inc min
//    MINUTES
    minutes_ones = minutes % 10;           // Repeat for minutes
    if (minutes>=10){
     minutes_tens = minutes / 10 ;}
    else {
      minutes_tens = 0;}
if (minutes>=60){
  //   minutes_tens = minutes / 10 ;}
  //  else {
        minutes_ones = 0;
      minutes_tens = 0;
        minutes = 0 ;
        hours ++;}                    // inc hour
// to adjust the 24
    hours_ones = hours % 10;               // Repeat for seconds
    if (hours>=10){
     hours_tens = hours / 10 ;}
    else {
      hours_tens = 0;}
  // here is the 24 hours reset
    if (hours>=24){
   //  hours_tens = hours / 10 ;}
   // else {
     seconds_ones = 0;            // reset to cero
     seconds_tens = 0;
     minutes_ones = 0;
     minutes_tens = 0;
     hours_ones = 0;
     hours_tens = 0;
     seconds = 0;
     minutes = 0;
     hours = 0;}
// send out the serial time displayed
void Serialtime_out() {
  ///// serial output of time
  Serial.println("Your Time is");   // send an initial string
  Serial.print(hours_tens);
  Serial.print(hours_ones);
  Serial.print(":");
  Serial.print(minutes_tens);
  Serial.print(minutes_ones);
  Serial.print(":");
  Serial.print(seconds_tens);
  Serial.print(seconds_ones);
  Serial.println(" ");   // send an initial string
   Serialtime_out();
So, if there is serial data to read, and if the first character is a t, call this function. OK.
Then, regardless of whether or not there is any serial data available, you read the next 8 bytes. Not a real good move.
What is sending the time to the serial port?
This might work if you had gotten 7 characters. What if you hadn't?
