Updating to newer Arduino IDE
I have Arduino IDE 1.6.4 on my Windows 8 laptop computer and Arduino IDE 1.6.7 on my Windows 10 desktop computer. I would like to update both (or at least one) to the newer Arduino IDE 1.8.0. I was told by others that I all that I need to do is to download the Arduino IDE 1.8.0 and that it will automatically take care of the older Arduino IDE that I presently have on my computer. Is this true? If not, could someone please direct me to some step-by-step instructions on how to update an older IDE to a newer one? I have some valued sketches on these older IDEs, should I make copies before I update? Any advice would be greatly appreciated. Thanks.
If you use the "Windows Installer" download link and the previous installation also used the installer then installing the new version will first uninstall the last version. If you use the "Windows ZIP file for non admin install" then there is no installation process, you just unzip the file and put the unzipped folder anywhere you like and the previously installed version will still be there until you remove it.
BryAB:
If you use the installer the files in the Arduino IDE installation folder will be deleted. You should never store any of your own files in that folder. The files in your sketchbook folder and anywhere else will be left alone. Of course it's always a good idea to back up irreplaceable files.
Some other information attached if you are going to remove an IDE
CLEAN UP BEFORE INSTALLING ANOTHER COPY OF THE IDE OR ARDUINO CREATE.pdf (334 KB)
darshan07:
First of all, Arduino is open source platform. Here are few steps for updating your arduino IDE:
  1. Plug in your Arduino to the computer with a USB Cable.
  2. Go to Start -> Control Panel -> System and Security -> Device Manager.
  3. You will see the connected Arduino board name. Right click on it and click on Update Drivers.
  4. A new window will show up click on Browse.
  5. Then Browse for the Arduino software in C: Program Files/Arduino/drivers.
  6. Click next to finish.
don't do that if you use the installer
my upload is showing all of these , pls what should i do. i have downloaded new ide of 1.8.3 version to no avail. pls help!!!
Arduino: 1.6.5 (Windows 8), Board: "Arduino Uno"
In file included from C:\Users\Henry\Documents\Arduino\libraries\rfid-master\src/MFRC522.h:78:0,
from sketch_jul20a.ino:3:
C:\Users\Henry\Documents\Arduino\libraries\rfid-master\src/require_cpp11.h:9:2: error: #error "This library needs at least a C++11 compliant compiler, maybe compiler argument for C++11 support is missing or if you use Arduino IDE upgrade to version >=1.6.6"
In file included from sketch_jul20a.ino:3:0:
C:\Users\Henry\Documents\Arduino\libraries\rfid-master\src/MFRC522.h:142:9: error: 'constexpr' does not name a type
static constexpr byte FIFO_SIZE = 64; // The FIFO is 64 bytes.
C:\Users\Henry\Documents\Arduino\libraries\rfid-master\src/MFRC522.h:142:9: note: C++11 'constexpr' only available with -std=c++11 or -std=gnu++11
C:\Users\Henry\Documents\Arduino\libraries\rfid-master\src/MFRC522.h:144:9: error: 'constexpr' does not name a type
static constexpr uint8_t UNUSED_PIN = UINT8_MAX;
C:\Users\Henry\Documents\Arduino\libraries\rfid-master\src/MFRC522.h:144:9: note: C++11 'constexpr' only available with -std=c++11 or -std=gnu++11
C:\Users\Henry\Documents\Arduino\libraries\rfid-master\src/MFRC522.h:371:111: error: 'nullptr' was not declared in this scope
StatusCode PCD_TransceiveData(byte *sendData, byte sendLen, byte *backData, byte *backLen, byte *validBits = nullptr, byte rxAlign = 0, bool checkCRC = false);
C:\Users\Henry\Documents\Arduino\libraries\rfid-master\src/MFRC522.h:372:112: error: 'nullptr' was not declared in this scope
StatusCode PCD_CommunicateWithPICC(byte command, byte waitIRq, byte *sendData, byte sendLen, byte *backData = nullptr, byte *backLen = nullptr, byte *validBits = nullptr, byte rxAlign = 0, bool checkCRC = false);
C:\Users\Henry\Documents\Arduino\libraries\rfid-master\src/MFRC522.h:372:137: error: 'nullptr' was not declared in this scope
C:\Users\Henry\Documents\Arduino\libraries\rfid-master\src/MFRC522.h:372:164: error: 'nullptr' was not declared in this scope
C:\Users\Henry\Documents\Arduino\libraries\rfid-master\src/MFRC522.h: In constructor 'MFRC522::MFRC522()':
C:\Users\Henry\Documents\Arduino\libraries\rfid-master\src/MFRC522.h:337:22: error: 'UNUSED_PIN' was not declared in this scope
MFRC522() : MFRC522(UNUSED_PIN, UNUSED_PIN) {};
Multiple libraries were found for "Servo.h"
Used: C:\Program Files (x86)\Arduino\libraries\Servo
Not used: C:\Users\Henry\Documents\Arduino\libraries\ESP32-Arduino-Servo-Library-master
Error compiling.
enabled in File > Preferences.
You are using version 1.6.5 of the IDE.
As noted in the errors, that library is not compatible with version 1.6.5.
While you may have downloaded 1.8.3 - that's not enough, you need to actually install and use it (the compiler output clearly states that it's still 1.6.5). Uninstall version 1.6.5, and install the version 1.8.x that you downloaded (why not 1.8.5?)
C:\Users\SAI\Documents\Arduino\libraries\generic_storage-master/FAT/FatFS/src/ff.c: In function 'f_write':
C:\Users\SAI\Documents\Arduino\libraries\generic_storage-master/FAT/FatFS/src/ff.c:2880:1: error: unable to find a register to spill in class 'POINTER_REGS'
C:\Users\SAI\Documents\Arduino\libraries\generic_storage-master/FAT/FatFS/src/ff.c:2880:1: error: this is the insn:
(insn 216 215 217 33 (set (reg:HI 26 r26)
(reg/f:HI 194)) C:\Users\SAI\Documents\Arduino\libraries\generic_storage-master/FAT/FatFS/src/ff.c:2837 83 {*movhi}
(nil))
C:\Users\SAI\Documents\Arduino\libraries\generic_storage-master/FAT/FatFS/src/ff.c:2880: confused by earlier errors, bailing out
lto-wrapper: C:\Users\SAI\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc returned 1 exit status
c:/users/sai/appdata/local/arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
sir please help me
sai7714:
This is a compiler bug. You can find more information and a workaround here:
