Upgrade GCC ESP32-WROOM-32
Hello everybody.
I'm having a problem running a code on my ESP32, which errors are multiple and are almost identical (only the variable names change): 'audio_tools::mime_pcm' declared as an 'inline' variable INLINE_VAR const char* mime_pcm = "audio/pcm";
This is the code in question that I'm trying to run on the ESP32:
 * @file streams-audiokit-webserver_wav.ino
 *  This sketch reads sound data from the AudioKit. The result is provided as WAV stream which can be listened to in a Web Browser
 * @author Phil Schatzmann
 * @copyright GPLv3
#include "AudioTools.h"
//#include "AudioLibs/AudioKit.h"
AudioWAVServer server("ssid","pasw");
I2SStream i2sStream;
ConverterFillLeftAndRight<int16_t>filler(LeftIsEmpty);
// Arduino setup
void setup(){
  AudioLogger::instance().begin(Serial, AudioLogger::Info);
  // start i2s input with default configuration
  Serial.println("starting I2S...");
  auto config = i2sStream.defaultConfig(RX_MODE);
  config.i2s_format = audio_tools::I2S_STD_FORMAT;
  config.sample_rate = 22050;
  config.channels = 2;
  config.bits_per_sample =16;
  i2sStream.begin(config);
  Serial.println("I2S started");
  // start data sink
  server.begin(i2sStream, config, &filler);
// Arduino loop
  // Handle new connections
  server.doLoop();
Click here to have the zip with the examples and the other file of Phil Schatzmann
I searched on the internet and from what I understand it's a GCC problem (currently I have version 5.2), but I don't know how to upgrade.
I also looked at the Espressif documentation and other Topic of Arduino Forum but I don't understand where I have to change the things and what to really do.
Can anyone help me? I can not go on.
Thank you for your availability and attention
Your topic has been moved to a more suitable location on the forum as this has nothing to do with Avrdude, stk500 or Bootloader.
I fixed the problem in this GitHub Topic.
Warning: I have not updated the GCC, but I have changed a parameter of a file.
