upgraded to Windows 10 Pro. Arduino.exe doesn't work at all
I upgraded to window 10 pro and i reinstalled all applications again.
but, somehow, even though i re-download and reinstall arduino software, its execution keep failing.
if i double click and execution file, arduino.exe, the small window is popped up and showing the status of booting of the application. After that, it's supposed to be arduino editor window, nothing happen but it creates a log file that explaning the crash.
please let me know how to solve this problem.
Thanks.
P.S. the detail of the log is here.
A fatal error has been detected by the Java Runtime Environment:
EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00008a2c, pid=11136, tid=10728
JRE version: Java(TM) SE Runtime Environment (8.0_66-b17) (build 1.8.0_66-b17)
Java VM: Java HotSpot(TM) Client VM (25.66-b17 mixed mode windows-x86 )
Problematic frame:
C 0x00008a2c
Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
If you would like to submit a bug report, please visit:
Crash Report
The crash happened outside the Java Virtual Machine in native code.
See problematic frame for where to report the bug.
****uhmmm it has a number of character limit to post...
U can check the detail in follow link
Make sure you have Java installed.
Learn how to "attach" JPG files into your post.
Many people including myself will not copy and post a link to someone's Dropbox.com. I don't want to bother.
