Upgrading Arduino
Hi All,
I'm running Win7 and have Arduino.exe installed in My Documents ie "My Documents\Arduino\Arduino.exe" It is currently Version 1.0.1 and I would like to upgrade to 1.0.3. What is the correct method of performing the upgrade and overwriting of files?
Neil.
I installed my versions side by side, including beta versions. Then I realized any user created stuff was saved elsewhere, so uninstalling old versions was as easy as deleting folders and shortcuts.
The IDE and its contents are self-contained. So you simply run out of a new folder.
This is why you never put libraries in the "Libraries" folder of the Arduino folder. Instead you put them in your My Documents/Arduino/libraries folder so that upgrades are seamless.
When upgrading is it a simple matter then of just starting 1.0.new not 1.0.old from a new folder?
What about the USB driver thing, as one has to do with a virgin PC?
Once the driver is installed one time, you should be good to go.
CrossRoads: Once the driver is installed one time, you should be good to go.
I'll give that a try then...... I vaguely recall that I started out on 1.0 so I've probably been through one successful upgrade to 1.0.1 anyway.
