I am trying to upgrade the scanning ultrasonic SONAR project. I want to add some buttons on the Processing Screen that will change Azimuth, Bearing, Range and Tilt for a second servo. I started with the handshaking Demo.I have the SONAR data coming in but am having trouble getting the pan and tilt working. Is anyone else looking to build a robot scanning SONAR unit? I welcome any assistance.
Arduino code
char val; // Data received from the serial port
int ledPin = 13; // Set the pin to digital I/O 13
boolean ledState = LOW; //to toggle our LED
// sonar init////////////////////////////////////////////////////
#include <NewPing.h>
#define TRIGGER_PIN 3 // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN 4 // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
//////////////////pan and tilt init/////////////////////////////
#include <Servo.h>
Servo Servo_1;
Servo Servo_2;
pinMode(ledPin, OUTPUT); // Set pin as OUTPUT
//initialize serial communications at a 9600 baud rate
establishContact(); // send a byte to establish contact until receiver responds
//pan and tilt setup////////////////////////////////////////////////////////
pinMode(1,OUTPUT);
Servo_1.attach(5); //analog pin 0
Servo_2.attach(6); //analog pin
if (Serial.available() > 0) { // If data is available to read,
val = Serial.read(); // read it and store it in val
if(val == '1') //if we get a 1
manualservomove();
ledState = !ledState; //flip the ledState
digitalWrite(ledPin, ledState);
delay(100);
else {
//GetRange();
Serial.println(sonar.ping_cm());
//Serial.println("q"); //send back a hello world
delay(50);
void establishContact() {
while (Serial.available() <= 0) {
Serial.println("A"); // send a capital A
delay(300);
void GetRange(){
delay(50); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
// Serial.print("Ping: ");
Serial.print(sonar.ping_cm()); // Send ping, get distance in cm and print result (0 = outside set distance range)
//Serial.println("cm");
void manualservomove()
static int v = 0;
if ( Serial.available()) {
char val = Serial.read();
switch(val) {
case '0'...'9':
v = v * 10 + val - '0';
case 'a':
Servo_1.write(v);
Serial.println(v);
v = 0;
case 'b':
Servo_2.write(v);
Serial.println(v);
v = 0;
void buttons(){
if(Serial.available()){ //id data is available to read
if(val == 'r'){ //if r received
digitalWrite(13, HIGH); //turn on red led
if(val == 'l'){ //if b received
digitalWrite(13, HIGH); //turn on blue led
if(val == 'y'){ //if y received
digitalWrite(13, HIGH); //turn on yellow led
if(val == 'f'){ //if f received
digitalWrite(11, LOW); //turn off all led
digitalWrite(12, LOW);
digitalWrite(13, LOW);
Processing code
import processing.serial.*; //import the Serial library
Serial myPort; //the Serial port object
String val;
// since we're doing serial handshaking,
// we need to check if we've heard from the microcontroller
boolean firstContact = false;
////pnt//////////
import controlP5.*;
ControlP5 cp5;
int pan = 10;
int tilt = 10;
Serial port;
//ControlP5 cp5; //create ControlP5 object
PFont font;
size(900, 900);
noStroke();
port = new Serial(this, Serial.list()[0], 115200);
//size(200, 200); //make our canvas 200 x 200 pixels big
size(900, 900);
// initialize your serial port and set the baud rate to 9600
// port = new Serial(this, Serial.list()[0], 115200);
port.bufferUntil('\n');
// myPort = new Serial(this, Serial.list()[0], 115200);
// myPort.bufferUntil('\n');
///////pan n tilt//////
cp5 = new ControlP5(this);
// add a horizontal slider for pan
cp5.addSlider("pan")
.setPosition(300, 30)
.setRange(0, 180)
.setValue(81)
// add a horizontal slider for tilt
cp5.addSlider("tilt")
.setPosition(300, 60)
.setRange(0, 180)
.setValue(146)
void draw() {
/////pnt/////////////
// output the servo positions for servos
// port.write("b"+pan);
// port.write("a"+tilt);
void serialEvent( Serial port) {
//put the incoming data into a String -
//the '\n' is our end delimiter indicating the end of a complete packet
val = port.readStringUntil('\n');
//make sure our data isn't empty before continuing
if (val != null) {
//trim whitespace and formatting characters (like carriage return)
val = trim(val);
println(val);
//look for our 'A' string to start the handshake
//if it's there, clear the buffer, and send a request for data
if (firstContact == false) {
if (val.equals("A")) {
port.clear();
firstContact = true;
port.write("A");
println("Serial Link Established");
} else { //if we've already established contact, keep getting and parsing data
println(val);
if (mousePressed == true)
{ //if we clicked in the window
port.write("b"+pan);//send movement data for servos
port.write('1'); //send a 1
println("1");
// when you've parsed the data you have, ask for more:
port.write("A");
