Hi @zackar. The tool used to upload compiled binaries to the Due is named "bossac".
The versions of bossac used by Arduino for the Due are available from these download links:
"name": "bossac",
"version": "1.5-arduino",
"systems": [
"host": "arm-linux-gnueabihf",
"url": "http://downloads.arduino.cc/bossac-1.5-arduino2-arm-linux-gnueabihf.tar.bz2",
"archiveFileName": "bossac-1.5-arduino2-arm-linux-gnueabihf.tar.bz2",
"checksum": "SHA-256:7b61b7814e5b57bcbd853439fc9cd3e98af4abfdd369bf039c6917f9599e44b9",
"size": "199550"
"host": "i686-mingw32",
"url": "http://downloads.arduino.cc/bossac-1.5-arduino2-mingw32.tar.gz",
"archiveFileName": "bossac-1.5-arduino2-mingw32.tar.gz",
"checksum": "SHA-256:9d849a34f0b26c25c6a8c4d741cd749dea238cade73b57a3048f248c431d9cc9",
"size": "222283"
"host": "x86_64-apple-darwin",
"url": "http://downloads.arduino.cc/bossac-1.5-arduino2-i386-apple-darwin14.3.0.tar.gz",
"archiveFileName": "bossac-1.5-arduino2-i386-apple-darwin14.3.0.tar.gz",
"checksum": "SHA-256:8f07e50a1f887cb254092034c6a4482d73209568cd83cb624d6625d66794f607",
"size": "64120"
"host": "x86_64-pc-linux-gnu",
"url": "http://downloads.arduino.cc/bossac-1.5-arduino2-x86_64-linux-gnu.tar.gz",
"archiveFileName": "bossac-1.5-arduino2-x86_64-linux-gnu.tar.gz",
"checksum": "SHA-256:42785329155dcb39872d4d30a2a9d31e0f0ce3ae7e34a3ed3d840cbc909c4657",
"size": "30431"
"host": "i686-pc-linux-gnu",
"url": "http://downloads.arduino.cc/bossac-1.5-arduino2-i486-linux-gnu.tar.gz",
"archiveFileName": "bossac-1.5-arduino2-i486-linux-gnu.tar.gz",
"checksum": "SHA-256:ac56e553bbd6d992fa5592ace90996806230ab582f2bf9f8590836fec9dabef6",
"size": "29783"
(I didn't bother to extract them out of the JSON data format they happen to be in, but you should be able to find them.
The official version of BOSSA is here:
https://www.shumatech.com/web/products/bossa
"bossac" is the command line tool. They also provide a GUI tool.
and Arduino's fork here:
Try this:
- Select File > Preferences from the Arduino IDE menus.
- Check the checkbox next to Show verbose output during: ☐ upload.
- Click the OK button.
- Upload any sketch to your Due.
- Wait for the upload process to finish.
Now check the contents of the black output panel at the bottom of the Arduino IDE window (you might need to scroll up to see it all). Here, you will see a command that looks something like this:
"C:\Users\per\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino/bossac.exe" -i -d --port=COM11 -U false -e -w -b "C:\Users\per\AppData\Local\Temp\arduino-sketch-2E5C65403DD7742EF8C89DBAFDB1A5CB/sketch_sep13a.ino.bin" -R
This is the bossac
command that was used for the upload.
Unfortunately, running this command from the command line won't result in a successful upload. The reason is because the Arduino IDE first sends a special signal to the board by quickly opening and then closing a serial port connection at 1200 baud. That signal tells the board to prepare to receive an upload. This "1200 bps touch" signal is not produced by bossac, but instead by the IDE.
For this reason, you might find that it is actually more convenient to use Arduino CLI instead of bossac directly:
https://arduino.github.io/arduino-cli/latest/
Alternatively, you could create your own bespoke program to produce this "1200 bps touch" signal before running the bossac command.
