I have an ESP8266 that is working with AT commands on Arduino MEGA using serial monitor and an bare minimum sketch (empty sketch) with baud rate 115200, TX pin 1, RX pin 0. But I want to use this code to upload data to thingspeak.com using an API key but it is not working. I tried many solutions but nothing. Is something wrong with this code?
Note: This code should be a part of another code on arduino MEGA
#include <SoftwareSerial.h>
// LED
int ledPin = 13;
int sensor_pin=A0; // variable for sensor
float sample=0;
float bat_volt =0; // for temperature
// replace with your channel's thingspeak API key
String apiKey = "DUT8RMTFY2B1XCAF";
// connect 1 to TX of Serial USB
// connect 0 to RX of serial USB
SoftwareSerial ser(0,1); // RX, TX
// this runs once
// initialize the digital pin as an output.
pinMode(ledPin, OUTPUT);
// enable debug serial
// enable software serial
ser.begin(115200);
// reset ESP8266
ser.println("AT+RST");
// the loop
// blink LED on board
digitalWrite(ledPin, HIGH);
delay(200);
digitalWrite(ledPin, LOW);
voltage();
esp_8266();
void voltage()
sample=0;
for(int i=0;i<150;i++)
sample+=analogRead(sensor_pin); //read the value from the sensor
delay(2);
sample=sample/150;
bat_volt = sample*(4.76/1024)*(12/2); // R1+R2/R2 // R1=10k and R2=2k
void esp_8266()
// convert to string
char buf[32];
String strVolt = dtostrf( bat_volt, 4, 1, buf);
Serial.print(strVolt);
Serial.println(" V");
// TCP connection
String cmd = "AT+CIPSTART=\"TCP\",\"";
cmd += "184.106.153.149"; // api.thingspeak.com
cmd += "\",80";
ser.println(cmd);
if(ser.find("Error")){
Serial.println("AT+CIPSTART error");
return;
// prepare GET string
String getStr = "GET /update?api_key=";
getStr += apiKey;
getStr +="&field1=";
getStr += String(strVolt);
getStr += "\r\n\r\n";
// send data length
cmd = "AT+CIPSEND=";
cmd += String(getStr.length());
ser.println(cmd);
if(ser.find(">")){
ser.print(getStr);
else{
ser.println("AT+CIPCLOSE");
// alert user
Serial.println("AT+CIPCLOSE");
// thingspeak needs 15 sec delay between updates
delay(16000);
