Upload error: Failed uploading: uploading error: exit status 1
I was trying to upload code on an arduino using another arduino as ISP ,it did not work , both are Arduino UNO R3 , one is SMD another is DIP . I uploaded the ISP code to Arduino SMD and then uploaded the blink code using the option "Upload Using programmer" to the Arduino DIP . The code worked but now when i use the same Arduino DIP directly with pc using usb its not working ,no code is wokring , there no pins connected to anything only the last blink code is working and yes it used to work properly , i have been using it for last 3 months , used many types of sensors , peripherals . Its giving me this code error :
FQBN: arduino:avr:uno
Using board 'uno' from platform in folder: C:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\DilipKumar\AppData\Local\arduino\sketches\BD31EB21B19B67A6371A1FF40E9B494E\sketch\eeprom_clear.ino.cpp -o nul
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
  -> candidates: [EEPROM@2.0]
C:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -IC:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\EEPROM\src C:\Users\DilipKumar\AppData\Local\arduino\sketches\BD31EB21B19B67A6371A1FF40E9B494E\sketch\eeprom_clear.ino.cpp -o nul
Generating function prototypes...
C:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -IC:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\EEPROM\src C:\Users\DilipKumar\AppData\Local\arduino\sketches\BD31EB21B19B67A6371A1FF40E9B494E\sketch\eeprom_clear.ino.cpp -o C:\Users\DilipKumar\AppData\Local\Temp\3986844346\sketch_merged.cpp
C:\Users\DilipKumar\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\DilipKumar\AppData\Local\Temp\3986844346\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\DilipKumar\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\DilipKumar\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\DilipKumar\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\DilipKumar\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "C:\\Users\\DilipKumar\\AppData\\Local\\arduino\\sketches\\BD31EB21B19B67A6371A1FF40E9B494E\\sketch\\eeprom_clear.ino.cpp" -o "C:\\Users\\DilipKumar\\AppData\\Local\\arduino\\sketches\\BD31EB21B19B67A6371A1FF40E9B494E\\sketch\\eeprom_clear.ino.cpp.o"
Compiling libraries...
Compiling library "EEPROM"
Compiling core...
Using precompiled core: C:\Users\DilipKumar\AppData\Local\arduino\cores\arduino_avr_uno_3787d44bd03907b8ac24e18ea823d4de\core.a
Linking everything together...
"C:\\Users\\DilipKumar\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\DilipKumar\\AppData\\Local\\arduino\\sketches\\BD31EB21B19B67A6371A1FF40E9B494E/eeprom_clear.ino.elf" "C:\\Users\\DilipKumar\\AppData\\Local\\arduino\\sketches\\BD31EB21B19B67A6371A1FF40E9B494E\\sketch\\eeprom_clear.ino.cpp.o" "C:\\Users\\DilipKumar\\AppData\\Local\\arduino\\sketches\\BD31EB21B19B67A6371A1FF40E9B494E/..\\..\\cores\\arduino_avr_uno_3787d44bd03907b8ac24e18ea823d4de\\core.a" "-LC:\\Users\\DilipKumar\\AppData\\Local\\arduino\\sketches\\BD31EB21B19B67A6371A1FF40E9B494E" -lm
"C:\\Users\\DilipKumar\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\DilipKumar\\AppData\\Local\\arduino\\sketches\\BD31EB21B19B67A6371A1FF40E9B494E/eeprom_clear.ino.elf" "C:\\Users\\DilipKumar\\AppData\\Local\\arduino\\sketches\\BD31EB21B19B67A6371A1FF40E9B494E/eeprom_clear.ino.eep"
"C:\\Users\\DilipKumar\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\DilipKumar\\AppData\\Local\\arduino\\sketches\\BD31EB21B19B67A6371A1FF40E9B494E/eeprom_clear.ino.elf" "C:\\Users\\DilipKumar\\AppData\\Local\\arduino\\sketches\\BD31EB21B19B67A6371A1FF40E9B494E/eeprom_clear.ino.hex"
Using library EEPROM at version 2.0 in folder: C:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\EEPROM
"C:\\Users\\DilipKumar\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\DilipKumar\\AppData\\Local\\arduino\\sketches\\BD31EB21B19B67A6371A1FF40E9B494E/eeprom_clear.ino.elf"
Sketch uses 766 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM12" -b115200 -D "-Uflash:w:C:\Users\DilipKumar\AppData\Local\arduino\sketches\BD31EB21B19B67A6371A1FF40E9B494E/eeprom_clear.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\DilipKumar\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM12
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x77
avrdude done.  Thank you.
I moved your topic to an appropriate forum category @jayant_d.
In the future, when creating a topic please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
There is a program called a "bootloader" is stored in a special area of the memory in the primary microcontroller of your Arduino board. This program receives the data sent by the computer when you upload a sketch to the board.
When you use Arduino IDE's "Upload Using Programmer" to upload a sketch, you erase the bootloader on the target board. It is expected that attempts to upload directly to the board via the USB cable will fail with the "... programmer is not responding ..." errors if the board doesn't have a bootloader.
So if you want to switch back to uploading directly to the board via USB again after performing an "Upload Using Programmer" operation, then you must first connect the ISP programmer to the target and perform a Tools > Burn Bootloader operation on the board to replace the bootloader.
Thanx , It worked for me.
i also considered ( https://youtu.be/TtC6crf_EP4?si=AlfRWFqdksAhaoa5 )
You are welcome. I'm glad it is working now.
Regards, Per
