Hi
I just purchased a Arduino Uno V3 board from Radio Shack today. It has a reset button on next to the usb connector. I installed the latest software Arduino 1.0 and loaded the usb drivers for Uno. I'm using a older laptop with Windows 2000. I loaded the sketch "blink" and changed the delay to 500ms. I selected "Board" to be "Uno" and "Com Port" of "9" which windows says is the comport. Then selected "Programmer" "Arduino as isp".
Did I select the correct things? I get an error message as follows:
Binary sketch size: 1026 bytes (of a 32256 byte maximum)
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x41
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x42
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Thanks
Don
