upload error
Hi there,
my OS is OS X High Sierra and i use now IDE 1.8.5 2017/10/2
but i also use the normal one.
Become these error, and i can’t fix it.
Arduino: 1.8.5 Hourly Build 2017/10/02 01:12 (Mac OS X), Board: “Arduino Nano, ATmega328”
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/oliverwiemer/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/oliverwiemer/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/oliverwiemer/Documents/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10805 -build-path /var/folders/sd/t6q091jn7n95qrdlxnl0v7x40000gn/T/arduino_build_248517 -warnings=default -build-cache /var/folders/sd/t6q091jn7n95qrdlxnl0v7x40000gn/T/arduino_cache_13902 -prefs=build.warn_data_percentage=75 -verbose …
“/var/folders/sd/t6q091jn7n95qrdlxnl0v7x40000gn/T/arduino_build_248517/hennentor.ino.elf” “/var/folders/sd/t6q091jn7n95qrdlxnl0v7x40000gn/T/arduino_build_248517/hennentor.ino.hex”
Bibliothek Timer im Ordner: /Users/oliverwiemer/Documents/Arduino/libraries/Timer (legacy) wird verwendet
Der Sketch verwendet 3552 Bytes (11%) des Programmspeicherplatzes. Das Maximum sind 30720 Bytes.
Globale Variablen verwenden 406 Bytes (19%) des dynamischen Speichers, 1642 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
REMOVE/bin/avrdude -C___REMOVE___/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbserial-A50285BI -b57600 -D -Uflash:w:/var/folders/sd/t6q091jn7n95qrdlxnl0v7x40000gn/T/arduino_build_248517/hennentor.ino.hex:i
java.io.IOException: Cannot run program “REMOVE/bin/avrdude”: error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at java.lang.Runtime.exec(Runtime.java:620)
at java.lang.Runtime.exec(Runtime.java:485)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:11)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:207)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
at processing.app.SketchController.upload(SketchController.java:713)
at processing.app.SketchController.exportApplet(SketchController.java:686)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2168)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.(UNIXProcess.java:247)
at java.lang.ProcessImpl.start(ProcessImpl.java:134)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
… 10 more
Beim Hochladen des Sketches ist ein Fehler aufgetreten
the driver maybe OK. the serial monitor is working well.
i think the problem was pointed here:
But, where can i configure or where should i place avrdude?
I hope you can under stand my problem and have a idea for trouble shooting.
best regards
Olli
Typically this sort of issue can be fixed by deleting /Users/oliverwiemer/Library/Arduino15 (or you can just rename the folder in case you want to recover it later.
That folder contains your preferences.txt file and also any hardware packages you have installed via Boards Manager so you would need to reconfigure via File > Preferences and re-install any Boards Manager hardware packages after doing this.
Please be very careful when deleting files from your computer. When in doubt back up!
thanks a lot. i will test it at night!
Great Thanks. it works!!! Thank you for the fast help!
