Upload Error
Every time I try to upload any sketch it comes up with a error. At first I though it was my code so I tried using an example, this still didn't work. After hours of trying I still couldn't get it to work so I ordered a new board. The new one still didn't work so I tried a different computer and that worked however I used a slow and broken laptop which is inconvenient. I should have tried another computer before ordering a new board but it is how it is. I have 2 Arduino Mega 2560 R3's and an HP Envy Desktop(The one that doesn't work). I used this computer before for Arduino and it worked before. Here is the error code, please help.
Arduino: 1.8.2 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 1462 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.
avrdude: ser_open(): can't open device "\.\COM5": Access is denied.
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: The handle is invalid.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
the selected serial port avrdude: stk500v2_getsync(): timeout communicating with programmer
does not exist or your board is not connected
option enabled in File -> Preferences.
The "Access is denied" error may be caused by another application having the COM port of your board open. Make sure there isn't another application running that might be doing this.
Try restarting your computer. Sometimes a glitch can cause the COM port to get stuck open and restarting fixes this.
