Windows 10 - 64 bit
Arduino software 1.8.5
Pro 328p 16mhz 5v board .
Drivers ftdichip.com 2.12.28
FTDI usb to serial cable
I am unable to load a file to the board . I have verified the loop back works per instructions by shorting reset and tx/rx pins . I have updated the drivers . A few old post talk about using old drivers but they were dated 2013 , so long old and the links are gone .
Plugging in the board the power light comes on and pin 13? green light flashes on and off for a few seconds . Start an upload , once compiled and starting board upload the green light flashes two or three times and then nothing and I get what looks like a typical avrdude: stk500_getsync() fault . I will post at the end .
Maybe 5 years ago I programed a board to run my automatic gearbox , I drowned it so need to replace the board . Two things have changed , one new computer and two new ftdi cable . I have tried to load on the old computer and I still get the same result , running win xp and a very old arduino program . However with my old cable I was loading just fine up until I lost the cable on another project . The second was the cable , I lost the cable a few months ago so brought a new one and now can not program , however it passed the loop back test .
Somewhere I have read on a help page about setting the baud rate and stop bits etc . I cant find this now but from 4 year old memory when I checked it last time it was set ok , can anyone point me to that info again . Or any other info that may help me program a new chip .
If it did not pass the loop back I would get a new cable . I have disabled windows firewalls/virus protection and it does not seem to help at all .
Thanks for any advice people may have .
Chris
fault text
Arduino: 1.8.5 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
Sketch uses 1490 bytes (4%) of program storage space. Maximum is 30720 bytes.
Global variables use 19 bytes (0%) of dynamic memory, leaving 2029 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xfb
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
