Continuing the discussion from Upload fails: "avrdude: stk500_recv(): programmer is not responding":
Hi @ptillisch, I'm having the same problem as @manu_rs, but I'm getting a different error message:
Sketch uses 2256 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 188 bytes (9%) of dynamic memory, leaving 1860 bytes for local variables. Maximum is 2048 bytes.
"/Users/artur_cytrynowicz/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude" "-C/Users/artur_cytrynowicz/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-P/dev/cu.usbmodem1101" -b115200 -D "-Uflash:w:/Users/artur_cytrynowicz/Library/Caches/arduino/sketches/569D7C2E55C8ADAF1017A39FDD468443/sketch_feb12a.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/artur_cytrynowicz/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/Users/artur_cytrynowicz/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem1101
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "/dev/cu.usbmodem1101": No such file or directory
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
How can I fix my problem?
