Upload fails: 'avrdude: ser_open(): can't set com-state for "\.\COM24"'
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 2278 bytes (7%) of program storage space. Maximum is 32256 bytes.
Global variables use 223 bytes (10%) of dynamic memory, leaving 1825 bytes for local variables. Maximum is 2048 bytes.
C:\Users\dell\Desktop\Amit\Arduino\hardware\tools\avr/bin/avrdude -CC:\Users\dell\Desktop\Amit\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM24 -b115200 -D -Uflash:w:C:\Users\dell\AppData\Local\Temp\arduino_build_601820/bt_car.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\dell\Desktop\Amit\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM24
An error occurred while uploading the sketch
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude done. Thank you.
option enabled in File -> Preferences.
Make sure you have the right port selected in the Arduino IDE's Tools > Port menu.
Make sure you don't have anything connected to pins 0 and 1 of your Uno while doing the Upload.
Please help. I am getting this error when uploading my sketch on Uno.
Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't set com-state for "\.\COM3"
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
Archiving built core (caching) in: C:\Users\Ivan\AppData\Local\Temp\arduino_cache_304496\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Sketch uses 960 bytes (2%) of program storage space. Maximum is 32256 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Ivan\AppData\Local\Temp\arduino_build_521870/sketch_sep15c.ino.hex:i
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
I'm getting the same error while uploading the code to the board.
I'm new to this and I'm just trying to follow what instructables has put up.
the error message is :
Sketch uses 21624 bytes (67%) of program storage space. Maximum is 32256 bytes.
Global variables use 910 bytes (44%) of dynamic memory, leaving 1138 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't set com-state for "\.\COM4"
SO what does this mean?
What is the second method of uploading the code? How to do it?
How to resolve this?
Thanks in advance.
haygreev:
Try restarting your computer. Sometimes the COM port will get stuck in a bad state and the restart fixes that.
