fs575
July 31, 2024, 7:12am
1
FQBN: arduino:avr:uno
Using board 'uno' from platform in folder: C:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\PC 24\AppData\Local\Temp\arduino\sketches\183329C80843F36C3F7424CA4D911CDD\sketch\Soil.ino.cpp -o nul
Generating function prototypes...
C:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\PC 24\AppData\Local\Temp\arduino\sketches\183329C80843F36C3F7424CA4D911CDD\sketch\Soil.ino.cpp -o C:\Users\PC 24\AppData\Local\Temp\2027294852\sketch_merged.cpp
C:\Users\PC 24\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\PC 24\AppData\Local\Temp\2027294852\sketch_merged.cpp
Compiling sketch...
"C:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino" "-IC:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard" "C:\Users\PC 24\AppData\Local\Temp\arduino\sketches\183329C80843F36C3F7424CA4D911CDD\sketch\Soil.ino.cpp" -o "C:\Users\PC 24\AppData\Local\Temp\arduino\sketches\183329C80843F36C3F7424CA4D911CDD\sketch\Soil.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\PC 24\AppData\Local\Temp\arduino\cores\arduino_avr_uno_100b98e742cabe262bb9677a8224dfea\core.a
Linking everything together...
"C:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\PC 24\AppData\Local\Temp\arduino\sketches\183329C80843F36C3F7424CA4D911CDD/Soil.ino.elf" "C:\Users\PC 24\AppData\Local\Temp\arduino\sketches\183329C80843F36C3F7424CA4D911CDD\sketch\Soil.ino.cpp.o" "C:\Users\PC 24\AppData\Local\Temp\arduino\sketches\183329C80843F36C3F7424CA4D911CDD/..\..\cores\arduino_avr_uno_100b98e742cabe262bb9677a8224dfea\core.a" "-LC:\Users\PC 24\AppData\Local\Temp\arduino\sketches\183329C80843F36C3F7424CA4D911CDD" -lm
"C:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\PC 24\AppData\Local\Temp\arduino\sketches\183329C80843F36C3F7424CA4D911CDD/Soil.ino.elf" "C:\Users\PC 24\AppData\Local\Temp\arduino\sketches\183329C80843F36C3F7424CA4D911CDD/Soil.ino.eep"
"C:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\PC 24\AppData\Local\Temp\arduino\sketches\183329C80843F36C3F7424CA4D911CDD/Soil.ino.elf" "C:\Users\PC 24\AppData\Local\Temp\arduino\sketches\183329C80843F36C3F7424CA4D911CDD/Soil.ino.hex"
"C:\Users\PC 24\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\Users\PC 24\AppData\Local\Temp\arduino\sketches\183329C80843F36C3F7424CA4D911CDD/Soil.ino.elf"
Sketch uses 2270 bytes (7%) of program storage space. Maximum is 32256 bytes.
Global variables use 230 bytes (11%) of dynamic memory, leaving 1818 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x7b
Failed uploading: uploading error: exit status 1
fs575
July 31, 2024, 7:13am
2
Compiling sketch...
"C:\\Users\\PC 24\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\PC 24\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\PC 24\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "C:\\Users\\PC 24\\AppData\\Local\\Temp\\arduino\\sketches\\183329C80843F36C3F7424CA4D911CDD\\sketch\\Soil.ino.cpp" -o "C:\\Users\\PC 24\\AppData\\Local\\Temp\\arduino\\sketches\\183329C80843F36C3F7424CA4D911CDD\\sketch\\Soil.ino.cpp.o"
Compiling core...
"C:\\Users\\PC 24\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\PC 24\\AppData\\Local\\Temp\\arduino\\sketches\\183329C80843F36C3F7424CA4D911CDD/Soil.ino.elf" "C:\\Users\\PC 24\\AppData\\Local\\Temp\\arduino\\sketches\\183329C80843F36C3F7424CA4D911CDD\\sketch\\Soil.ino.cpp.o" "C:\\Users\\PC 24\\AppData\\Local\\Temp\\arduino\\sketches\\183329C80843F36C3F7424CA4D911CDD/..\\..\\cores\\arduino_avr_uno_100b98e742cabe262bb9677a8224dfea\\core.a" "-LC:\\Users\\PC 24\\AppData\\Local\\Temp\\arduino\\sketches\\183329C80843F36C3F7424CA4D911CDD" -lm
"C:\\Users\\PC 24\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\PC 24\\AppData\\Local\\Temp\\arduino\\sketches\\183329C80843F36C3F7424CA4D911CDD/Soil.ino.elf" "C:\\Users\\PC 24\\AppData\\Local\\Temp\\arduino\\sketches\\183329C80843F36C3F7424CA4D911CDD/Soil.ino.eep"
"C:\\Users\\PC 24\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\PC 24\\AppData\\Local\\Temp\\arduino\\sketches\\183329C80843F36C3F7424CA4D911CDD/Soil.ino.elf" "C:\\Users\\PC 24\\AppData\\Local\\Temp\\arduino\\sketches\\183329C80843F36C3F7424CA4D911CDD/Soil.ino.hex"
"C:\\Users\\PC 24\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\PC 24\\AppData\\Local\\Temp\\arduino\\sketches\\183329C80843F36C3F7424CA4D911CDD/Soil.ino.elf"
hlp me
Hi @fs575 . Please add a reply here on this forum thread to tell us which Arduino board you are using.
Please be as specific as possible as some Arduino boards with similar names have significant differences and the forum helpers can only provide effective assistance if we are aware of which one is being used.
If you aren't sure how to describe which board you are using, you can provide the link to the online product listing you bought the board from and we'll proceed based on the information found there.
system
Closed
January 27, 2025, 8:13am
4
