Upload fails: "stk500_recv(): programmer is not responding"
I have an ELEGOO Uno R3 and after trying to connect to two different computers AND checking the ports, driver, boards and even installing the Chinese driver I keep getting upload errors. It'll work one time on occasion but it's always after I make some changes like changing the Programmer that it works once. Then every time after that it crashes and It won't work after that. it's like it adapts to make sure it doesn't upload because everything I've done to make it run before doesn't work now no matter how many times I try it. So I wanted to burn it following the official page instructions but the burn won't load either. I even removed my old IDE (2.3.2) to (1.8.18)
This is the error I get when upload worked:
Arduino: 1.8.18 (Windows 10), Board: "Arduino Uno"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Ebenezer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Error while burning bootloader.
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
option enabled in File -> Preferences.
And this is the one I got when it didn't work:
C:\Users\Ebenezer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Ebenezer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
         Using Port                    : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x15
This indicates that you're trying to upload via ICSP using an external programmer, not via USB. If it's via USB, the choice of programmer makes no difference.
How to I upload via USB because it is connected via the USB port, I don't know what ICSP means
ICSP is a way to program the board via a external programming device,
Stands for in circuit serial programming.
I believe there are settings in the menu, but I cannot recall them.
(Perhaps clicking around there might help?)
Not behind a PC at the moment. If not mistaken, it is sketch/upload (shortcut ctrl-U)
Upload using programmer would also be under the sketch menu (shortcut shift-ctrl-U)
When I run both Ctrl U and Shift+Ctrl+U I get this error
Sketch uses 4354 bytes (13%) of program storage space. Maximum is 32256 bytes.
Global variables use 482 bytes (23%) of dynamic memory, leaving 1566 bytes for local variables. Maximum is 2048 bytes.
C:\Users\Ebenezer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Ebenezer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM3 -b19200 -Uflash:w:C:\Users\Ebenezer\AppData\Local\Temp\arduino_build_802950/ArduinoISP.ino.hex:i
         Using Port                    : COM3
Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
Does it in both cases show stk500v1 and 19200?
Note
For upload over USB you will need to use ctrl-U.
Yes, in both cases.
In that case there might be something wrong with your <shift> key :wink:
Unfortunately I do not know why the IDE would think that you want to do an upload using programmer.
