I can't upload a sketch to an Uno Wifi rev 2. I believe the board is alive, and that the IDE and cabling are correct:
- The board is an Uno Wifi rev 2.
- I've gone through all the recommended checks, including verifying board type and interface port, with no success making the wifi board upload.
- The blynk-ser.sh script used with Blynk loads up and starts to cycle properly against the wifi board, which is why I don't think the board is dead and that I have the right port.
- The same USB cable and IDE always succeed uploading to an Uno (not Wifi), which will then respond via the end-to-end Blynk stack using the same interface script.
Here's my upload messages from the failing board:
Arduino: 1.8.13 (Mac OS X), Board: "Arduino Uno WiFi"
Sketch uses 9212 bytes (28%) of program storage space. Maximum is 32256 bytes.
Global variables use 395 bytes (19%) of dynamic memory, leaving 1653 bytes for local variables. Maximum is 2048 bytes.
/Users/press/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/press/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem143302 -b115200 -D -Uflash:w:/var/folders/x3/8mq7t3fj3h95_4q1nxzm2yv80000gn/T/arduino_build_820518/Button_-_Serial_USB.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/press/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/Users/press/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem143302
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
