I get the following message during upload process:
"get https://downloads.arduino.cc/packages/package_staging_index.json: dial tcp 149.202.160.25:443: connectex: A connection attempy failed because the connected party did not properly respond after a period of time, or established conection failed because connected host has failed to respond."
can this be a corporate firewall issue. all outbound connections should use the corporate proxy. If this is the case, would the issue be solved if I wasn't using the online IDE. I'm new at this so it may well be just a problem between the chair and keyboard...
Thanks.
AA
