I am getting a hang on the upload on a sketch that is 32,180 long.
If I comment out some code and get it back down to 32,132 it loads fine.
I have installed a function to report free SRAM and it says I have over 5k available.
The only way I have found to clear the hangup is to unplug the usb. This gives a timeout
error in the error window which I expect. No error reported until I pull the plug--just stops. Status led flashes normally until it hangs with the led either on or off.
I have tried two different XP machines and they both do the same.
I haven't tried the beta arduino ide.
Also, I don't know what bootloader is on the 2560.
Using Arduino 1.0.3
Any ideas how I should troubleshoot this ? Thanks
Make sure none of the strings in your sketch contain '!!!'. Some Arduino MEGA bootloaders use that as a signal to go into 'monitor mode' where they take commands from Serial Monitor to read and write memory. This causes a hang on upload.
Thanks, but I saw that when searching for what was causing it.
Seems strictly related to size of sketch. I can put in a few lines of Serial.print("xxxxx" ); and cause it
to hang. Whenever the sketch size goes over approximately 32,132 in hangs. My project still works as I can keep it under that for now, but have bigger plans in the future for this thing. I was looking for a way to test the program memory on the Ardunio, but didn't find a sketch to do that. I was wondering if it is getting a memory error on the load and stopping. I am assuming that the loader somehow verifies the data during the load process.
Well, Never assume anything I guess. I assumed that I didn't have any !!'s in my sketch and since it always loaded fine until I got to around 32,130+ bytes . Just too be sure I did a search this morning and in fact there were a couple of !! in a comment I had made to myself. Why it loads fine until the size hits a certain threshold seems a little weird, but oh well. Anyhow, I took them out and added some dummy code to get the size up and it loads fine now. Is this a ide or bootloader "Feature" that causes the hang.
Thanks for the feedback.
Mike
Hi again
Below is the actual comment I had made to myself. Since the code was commented out a while back I can't remember what I was doing on at the time. I have uploaded many times without problems with the !!!!!!!!'s comment and the code was block commented out too. It only presented a problem when the program crossed the size I mentioned earlier. At this point I am happy to just go with it as I don't have the problem after getting rid of the statements I was no longer using anyhow.
eedata[7] = highByte(pointer1); // These two commands don't change the data in eedata[7] and eedata[8]
eedata[8] = lowByte(pointer1); // What the Hell am I doing wrong!!!!!!!!
