I am using ESP 32 - CAM for uploading images. When i upload the image pixels are missing in it. Ideally, FRAMESIZE_UXGA(1600x1200) image size should be around 100Kb but I am recieving just 50 Kb,
I am guessing its a problem related to buffer.
#include "FS.h"
#include "SD_MMC.h"
#include <Wire.h>
#include <WiFi.h>
#include <Adafruit_Sensor.h>
#include "src/Adafruit_TSL2591/Adafruit_TSL2591.h"
#include "src/esp32-camera/esp_camera.h"
bool isCapture = false;
int minThreashold = 100;
Two thresholds can be set:
Lower Threshold - Any light sample on CHAN0 below this value
will trigger an interrupt
Upper Threshold - Any light sample on CHAN0 above this value
// Interrupt thresholds and persistance
#define TLS2591_INT_THRESHOLD_LOWER (1)
#define TLS2591_INT_THRESHOLD_UPPER (100)
#define TLS2591_INT_PERSIST (TSL2591_PERSIST_ANY) // Fire on any valid change
//#define TLS2591_INT_PERSIST (TSL2591_PERSIST_60) // Require at least 60 samples to fire
void setup(void)
if(!SD_MMC.begin()){
Serial.println("Card Mount Failed");
return;
uint8_t cardType = SD_MMC.cardType();
if(cardType == CARD_NONE){
Serial.println("No SD_MMC card attached");
return;
uint64_t cardSize = SD_MMC.cardSize() / (1024 * 1024);
Serial.printf("SD_MMC Card Size: %lluMB\n", cardSize);
Serial.printf("SPIRam Total heap %d, SPIRam Free Heap %d\n",ESP.getPsramSize(),ESP.getFreePsram());
void loop(void)
captureImage();
fileUpload();
camera_fb_t * fb = NULL;
size_t size_pic;
int counter = -1;
uint8_t* myImages;
void captureImage() {
Serial.println("Camera capture started");
int64_t fr_start = esp_timer_get_time();
int index = ++counter % 2;
Serial.println("Capture index:");
Serial.print( counter);
myImages=(uint8_t*) ps_malloc(100000*sizeof(uint8_t));
fb = esp_camera_fb_get();
myImages = fb->buf;
size_pic = fb->len;
if (!fb) {
Serial.println("Camera capture failed");
void fileUpload() {
Serial.println("inside file upload");
if (counter > -1) {
Serial.println("Captured images : ");
Serial.print(counter);
sendImage("asdw", "A54S89EF5");
String sendImage(String token, String message)
Serial.println("inside send image");
int index = --counter % 2;
String bodyTxt = body("message", message);
String bodyPic = body("imageFile", message);
String bodyEnd = String("--") + BOUNDARY + String("--\r\n");
size_t allLen = bodyTxt.length() + bodyPic.length() + fb->len + bodyEnd.length();
String headerTxt = header(token, allLen);
WiFiClient client;
if (!client.connect(SERVER, PORT))
return ("connection failed");
client.print(headerTxt + bodyTxt + bodyPic);
client.write(myImages, fb->len);
client.print("\r\n" + bodyEnd);
delay(5000);
long tOut = millis() + TIMEOUT;
while (client.connected() && tOut > millis())
if (client.available())
String serverRes = client.readStringUntil('\r');
return (serverRes);
free(myImages);
counter = -1;
String header(String token, size_t length)
String data;
data = F("POST /camera/saveCameraData/1/5c9e7ab9e9ee5102a406dd1f HTTP/1.1\r\n");
data += F("cache-control: no-cache\r\n");
data += F("Content-Type: multipart/form-data; boundary=");
data += BOUNDARY;
data += "\r\n";
data += F("User-Agent: PostmanRuntime/6.4.1\r\n");
data += F("Accept: */*\r\n");
data += F("Host: ");
data += SERVER;
data += F("\r\n");
data += F("accept-encoding: gzip, deflate\r\n");
data += F("Connection: keep-alive\r\n");
data += F("content-length: ");
data += String(length);
data += "\r\n";
data += "\r\n";
return (data);
String body(String content , String message)
String data;
data = "--";
data += BOUNDARY;
data += F("\r\n");
if (content == "imageFile")
data += F("Content-Disposition: form-data; name=\"image\"; filename=\"picture.jpg\"\r\n");
data += F("Content-Type: image/jpeg\r\n");
data += F("\r\n");
data += "Content-Disposition: form-data; name=\"" + content + "\"\r\n";
data += "\r\n";
data += message;
data += "\r\n";
return (data);
Thanks in advance for your help.
