Upload Issue!
I have a Creality CR-10 3D printer (310x310x410 printing limits). I have uploaded new firmware on a regular process when the supplier updates the file I update my firmware. This has always worked like a charm until last night when I tried to upload the latest to the printer. The attached photo shows the board and its chip.
Click here to see the image of the board!
I think the storage capacity is full and not sure why? Or is there a way to flush out all the data and start from scratch again.
When I try to upload I get this when I try to upload, it compiles everything but shows storage info.
Sketch uses 123108 bytes (94%) of program storage space. Maximum is 130048 bytes.
Global variables use 4664 bytes (28%) of dynamic memory, leaving 11720 bytes for local variables. Maximum is 16384 bytes.
I'm wondering what I can do to fix this.
And my arduino Settings are:
Boards:"Sanguino(1284P Boards)"
Processor: "ATmega1284 or ATmega1284P (16MHz)"
Port: "COM 5"
Programmer: "Arduino as ISP"
Any help I can get on this is greatly appreciated.
Your "storage capacity" isn't full. Any upload will erase the previous uploaded code.
I suggest that you post the complete error message.
ZenFrogCreations:
That happens every time you upload to your board. That message is just telling you the amount of memory on your board that the compiled code will use. It's just a helpful informational message. If it said it was over 100 percent of program storage space that would be a problem. Since it doesn't say that you're just getting all flustered over nothing.
ZenFrogCreations:
That just means it successfully compiled. There is no problem.
ZenFrogCreations:
Chill out and get back to your 3D printing.
pert is a better reader than I am.
pert:
Pert, thanks...chillin again. I must have had a brain glitch, for some reason I kept clicking the verify button instead of the upload.
Works as it should!
