upload issues
hi guys..
im trying to upload a code on a nodemcu board but im constantly getting error msgs. please help me out here
heres the code;
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
char auth[] = "84032ee45eeb4915996053f03ded2864";
char ssid[] = "VodafoneMobileWifi-A6C784";
char pass[] = "8067636675";
pinMode(D2,OUTPUT);
pinMode(D4, OUTPUT);
pinMode(D6,OUTPUT);
pinMode(D8,OUTPUT);
digitalWrite(D2,HIGH);
digitalWrite(D4,HIGH);
digitalWrite(D6,HIGH);
digitalWrite(D8,HIGH);
Blynk.begin(auth, ssid, pass);
Blynk.run();
and the error msg;
Arduino: 1.8.8 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 9600"
Sketch uses 279864 bytes (26%) of program storage space. Maximum is 1044464 bytes.
Global variables use 28872 bytes (35%) of dynamic memory, leaving 53048 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.6
2.6
esptool.py v2.6
Serial port COM11
Connecting......................................_____
Traceback (most recent call last):
File "C:\Users\Tino\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.1/tools/upload.py", line 25, in
esptool.main(fakeargs)
File "C:/Users/Tino/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.5.1/tools/esptool\esptool.py", line 2653, in main
esp.connect(args.before)
File "C:/Users/Tino/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.5.1/tools/esptool\esptool.py", line 468, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
Invalid library found in C:\Users\Tino\Documents\Arduino\libraries\libraries: no headers files (.h) found in C:\Users\Tino\Documents\Arduino\libraries\libraries
Invalid library found in C:\Users\Tino\Documents\Arduino\libraries\tools: no headers files (.h) found in C:\Users\Tino\Documents\Arduino\libraries\tools
option enabled in File -> Preferences.
You seem to have a 'libraries' directory inside your 'libraries' directory. Did you install a library incorrectly?
You seem to have a 'tools' directory inside your 'libraries' directory. Did you install a library incorrectly?
johnwasser is correct. It also looks like you are having trouble connecting. There are many possible causes of this. Did you select the correct port? Is your cable completely plugged in? Is your cable any good? Is your Arduino any good? Etc. Etc.
