Sketch uses 2702 bytes (41%) of program storage space. Maximum is 6586 bytes.
Global variables use 144 bytes (28%) of dynamic memory, leaving 368 bytes for local variables. Maximum is 512 bytes.
Failed uploading: uploading error: exit status 0xc0000135
Hi @dyinginthedarkness. I'm going to ask you to post the full verbose output from an upload attempt.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
Select File > Preferences... (or Arduino > Preferences... for macOS users) from the Arduino IDE menus.
The "Preferences" dialog will open.
Uncheck the box next to "Show verbose output during: ☑ compilation" in the "Preferences" dialog.
Check the box next to "Show verbose output during: ☐ upload".
Click the "OK" button.
Attempt an upload, as you did before.
After the upload fails, you'll see a button on the right side of the orange bar in Arduino IDE: Copy error messages. Click that button.
This copies the full output to the clipboard.
Open a forum reply here by clicking the "Reply" button.
Click the <CODE/> icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
This will paste the error output from the upload into the code block.
Move the cursor outside of the code tags before you add any additional text to your reply.
